In Tidal I can search Alice on a Hook and I get “Alice in Chains - Hung on a Hook”, but in local, if I run that search I get 0 results (I can only search an artist name, an album or a track, but not mix them). Is this normal behavior?
Hello @Dexter_prog, it is normal as the search is only limited to artists, album or tracks and rely on how it is sorted. For the Hung on a Hook, you can change how it is sorted by going in the metadata of the album so when you want to search it you can find with Alice on a Hook.
