Shake to Undo – How to disable?
On my iPad I have the Shake to Undo feature disabled system-wide. However, it still seems to be enabled inside Audirvana Remote, and I can’t find way of disabling it. Almost every time I set my iPad down on the couch while using Remote, I’m getting this:
What can be done about this?
