Maybe i am blind but i can´ t figure out the following:
All my albums (most classical music) in Audirvana (around 6.500) were basically ripped into itunes. I put a lot of time to give them the best meta data that my time allowed.
I love Audirvana and everything works fine for me (Macbook Air 2017 (mojave) > Audirvana -> Dirac -> Stello U3 -> Kondo KSL DAC).
The only challenge is: i can´t find in Audirvana what is in iTunes called “Year”. In this itunes data field i always wrote the recording date and every album in itunes has an entry for the year. Now when playing music in Audirvana (latest version) i can´t find it. Not on the Macbook, not in the Audirvana remote app.
What am i making wrong?
@RunHomeSlow,
thanks for your support!
Now it works fine on my MacbookAir, i can see the year of recording there now.
But: on the Audirvana remote on my iPad there remains everything unchanged - no year.
Anything i can do on the remote … can´t find it by myself.
THANK YOU!!!
Thanks again, RunHomeSlow.
Maybe Audirvana puts it on the To Do list. i know that a lot of (not only) classical music lovers would appreciate this. cannot be that difficult, right?
Hello @delgesu, for the moment we have made the choice to prioritize other development for the Remote but we do take notes of your suggestion for the Remote.
When I look at the Metadata I do not see all the info that you show in your screen grab. If I click on the song title I can click on the three dots that brings up more Metadata. When I try to scroll down the Metadata window switches back to the other view with much less information. How do I get the Metadata window to not switch over? Thx
Just wanted to support that idea, sorting by year and accessing metadatas of albums/tracks through remote are also very important for me, hopefully it’ll get in the dev schedule at some point
Thanks ^^
