Hi,
I have a problem with the Sign in window, that the sign in bar cannot be clicked…when I put my mouse cursor on it, the cursor stays in arrow form instead of switch into small hand form. Then if I click the sign in bar, nothing happened.
I try to close & reopen the sign in window for numerous times, usually with good result, except for today, no result at all.
Using windows 10.
I open the sign in window by click the audirvana icon in the program list from start menu, or by click the icon on task bar.
Has anyone had this problem?
Thanks for the help.
