Skipping songs in tidal
My tidal kept skipping songs while playing. For eg. When I play Adele 30 track 3. It skips / stops during playback at random point (?min?seconds)and may skip to a random track in the same album or just a random track of the same artist. Issue started around 1 or 2 months ago. Please address what needs to be done when I m streaming. Such case doesn’t happen for local files playback.
FYI
Audirvana Studio 2.8.2 (20802)
macOS Version 14.5 (Build 23F79) with 16GB physical RAM
Connected account of : chun pui wong
r8brain custom frequencies
48000Hz → 44100Hz
88200Hz → 44100Hz
176400Hz → 44100Hz
192000Hz → 44100Hz
352800Hz → 44100Hz
SW volume control: ON
AUTO: /Volumes/MELCO E-100/
Library database path: /Users/home/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 13738
Listening on 127.0.0.1 on port 51048
TIDAL: Connected as PREMIUM
Font size: regular
Language: English
My Music
Radios
Podcasts
Streaming
Use media keys for volume control: no
Use Apple Remote: no
Number of paired remotes: 4
Screen saver disabled: yes
Max. memory for audio buffers: 13764MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Schiit Audio Schiit Yggdrasil Unison USB
Model UID:Schiit Yggdrasil Unison USB :30BE:1001
UID:AppleUSBAudioEngine:Schiit Audio:Schiit Yggdrasil Unison USB :2100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Sample rate limitation: 44.1kHz
Selected device:Schiit Yggdrasil Unison USB
Manufacturer: Schiit Audio
Model name: Schiit Audio Schiit Yggdrasil Unison USB
Model UID: Schiit Yggdrasil Unison USB :30BE:1001
UID: AppleUSBAudioEngine:Schiit Audio:Schiit Yggdrasil Unison USB :2100000:1
USB Vendor ID: 0x30be
USB Product ID: 0x1001
ID 0x34
Audio buffer frame size : 27 to 4096 frames
Max volume alert: Disabled
Stream ID 0x35 2 channels starting at 1
24 virtual formats:
36 physical formats
Device #0: ID 0x34 Schiit Yggdrasil Unison USB
Device #1: ID 0x50 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
You can try lowering your playback pre-load memory to 4GB… You are using about 80% of your System RAM for playback pre-load buffering…
The other influencing factor is your network connection… are you using Wi-Fi or Ethernet in your internet connection?
Also, why are you forcing all sample-rates to 44.1kHz using custom settings in r8Brain? The Schiit DAC supports sample-rates up to 32/192kHz… I suggest that you use ‘Power of Two’ which will properly play all sample-rates… r8Brain will upsample 44.1kHz and 88,2kHz files to 176.4kHz and 48,kHz and 96kHz files to 192kHz and decimate/truncate 352.8kHz files to 176.4kHz or to the maximum sample-rate 192kHz… If you just disable upsampling, Audirvana will play all files below 192kHz in their native bit depth and sample-rate and truncate all files above 192kHz to 176.4kHz or 192kHz, when the DAC maximum sample-rate is set to 192kHz.
