Small UI glitch
Qobuz playlists
Preferences
Capture d’écran 2022-09-24 à 20.24.45
Thanks for your report, it will be fixed in the next update.
A small window placement glitch in technical view
When a semi hires file is detected, detection window is not placed back to its original position.
alignment in list mode
Capture d’écran 2022-10-01 à 19.10.15
Hello @Claude,
Do you still get this behaviors with the latest version of the beta?
Hi Antoine !
Misalignment in list view is still here. It’s far better (but not perfect) in technical view.
Capture d’écran 2022-10-18 à 13.22.26
