[SOLVED] There are too many installs for your license
Hello @yen,
I have removed all your computers from the license database.
You can now activate up to two computers.
To install Audirvana on your computers, you can proceed as follows:
  1. install trial version : https://audirvana.com/try/
  2. unlock it by loading your license key
thank you! it’s working now.
You know Damien I hadn’t listened with Audirvana for some time. I began listening again after your changes and really the sound is glorious!!
I’m having the same problem–had a new logic board installed and no more Audirvana! Can you help me?
Hello Damien,
I have the same issue, having Audirvana working fine on my main system (MacBookPro) but can’t install it on my second one (iMac). Could you please reset the license?
Hello @vieuxloj,
You can now activate up to two Mac computers.
To install Audirvana on your Mac, you can proceed as follows:
  1. install trial version : https://audirvana.com/try-mac/
Bonjour,
Suite au plantage de mon Macmini je doit réinstaller Audirvana sur une nouvelle machine et ne peux pas révoquer la licence de l’ancien.
Donc j’ai le message “Trop d’installations”
Pourriez vous révoquer l’ancienne licence ?
Merci
J.Christophe
Bonjour @Kool,
J’ai retiré tous vos ordinateurs de la base de données des licences.
Vous pouvez maintenant activer jusqu’à deux ordinateurs Mac.
Pour installer Audirvana sur votre Mac, vous pouvez procéder comme suit :
  1. installez la version d’essai : https://audirvana.com/try-mac/
  2. le déverrouiller en chargeant votre clé de licence
Hello @Antoine,
I didn’t deactivate older devices before re-install the OS or move to other mac, so I got this message.
Could you please reset the license count?
Thanks,
Hello Damien,
Hello @maruboz and @korstudio,
Hi Damien,
I am running Audirvana on my MacBook but would also like to run on my iMac but to many installs is flagged. Is it possible to reset the database please. Thank you.
Hello @Terry,
Hi @Antoine,
I tried PMing you this AM, I have the too many installs flag. Could you please reset my account in your database? Thanks!
Hello @deshpn,
Hello @Antoine,
I have the same issue.
Can you please initialize the license?
I would also appreciate if you could prepare a license management page for future use.
Thank you.
Hello @naviapis,
Same problem here with new iMac. I deleted Audirvana from all my computers, including the one other I want to keep it on and still get this message.
こんにちはダミアン、
私は同じ問題を抱えています。メインシステム(MacBookPro)ではAudirvanaが正常に動作していますが、2番目のシステム(iMac)にはインストールできません。ライセンスをリセットしていただけませんか?
OSを再インストールしたり、他のMacに移動したりする前に古いデバイスを非アクティブ化しなかったため、このメッセージが表示されました。
ライセンス数をリセットしていただけませんか?
