Hi @Antoine, Please help me out with the license. I have the same issue as the others.
Thanks.
Too many install on the license, and i can’t remove the Audirvana on the window 10 computer.
I tried to remove the Audirvana in my several computer. But I have not completed that work.
Can you help to remove the installed Audirvana?
Hello @trizvanov and @bananenbieger,
I have removed all your computers from the license database.
You can now activate up to two computers.
Thanks for that, @Antoine
I no longer receive that message.
However, what I get now is “There is no valid license available to continue execution of Audirvana”.
I purchased the license in 2017.
The license key you have is meant to be used on Audirvana 3.2. You received this message because you tried to use your license on Audirvana 3.5. I sent you a private message with the link to download Audirvana 3.2
Hello.
I did many reinstall where I forget to uninstall Audirvana. Could you please remove my computers form you database?
Best regards
Dominique
Bonjour @Clarexine,
J’ai retiré tous vos ordinateurs de la base de données des licences.
Vous pouvez maintenant activer jusqu’à deux ordinateurs Mac.
Pour installer Audirvana sur votre Mac, vous pouvez procéder comme suit :
HI Damien,
Please remove all my Mac computers from the license database so I can activate the ones I need.
order 58121735 from 2017-03-09
Thank you!
Hello Damien again,
Too many install. I bought new Mac and removed one of copy.
Cheers
Hello @szczemirek,
You can now activate up to two Mac computers.
To install Audirvana on your Mac, you can proceed as follows:
Hi Damien
I forgot to deactivate the account on my mac which I reinstalled. Can you remove all my licenses?
Thanks a lot
HI Damien
Could you please do the same for as getting the same error on my new MacBook and just want to use the software desperately.
Thank you
David
Hi there Damien,
I sent you a pm but seeing that the issue I have is being dealt with in this thread, I’m here to ask you.
Before I reinstalled W10 in my pc I didn’t deactivate my Audirvana license, could you remove my computers from the license,
thanks!
Hi , I have reinstall my windows 10 on laptop and facing the same issue , Can you kindly remove my license from all my windows machine only, I will also be re installing on my main Windows PC . Thanks
Hello @neaman,
You can now activate up to two PC running Windows 10.
To install Audirvana on your PC, you can proceed as follows:
Hello @JotBF2,
I also have too many installs on my licence. Please deactivate them so that I can start again.
Thanks!!
