Dear all,
Here are some of the issues I discovered when using Remote.
- When an album is displayed with all the available tracks, clicking on the “…” option at the top right corner above the list makes the application crashing.
- When something wrong appears (e.g. no connection with the drive that contains the audio files) no error message is visible on remote, you have to go back to the main Studio I/F
- Changing the audio devices is not easy: you have to select the currently playing track (even if there is nothing available to play) and in the new window, top right corner, you will find a button to change the audio device. Would be more user friendly if such option was available somewhere from the main window.
Eric
