That would be this:
Audirvana Studio 2.9.3 (20903)
Windows 11 (22631) x86_64 with 32GB physical RAM
Connected account of : Stefan XXXX
Available network interfaces:
Ethernet ({3e8c1c4f-d0fa-467a-81b5-XXXXX}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
VST3 plugin #0: C:\Program Files\Common Files\VST3\Ghz CanOpener Studio 3.vst3
ClassID: 5653544353335867687A2063616E6F70
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
AUTO: \diskstation\Media\Lossless Audio
Library database path: C:\Users\stefan\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 318
Listening on 2a02:1210:50e0:8500:9425:6039:XXXX:XXXX on port 51012
TIDAL: Connected as PREMIUM
UI theme: light
Font size: large
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 1
Screen saver disabled: no
Max. memory for audio buffers: 640MB
Local Audio Engine: ASIO 2
Driver version 1
ASIO MADIface USB
Model UID:ASIO MADIface USB
Device: 2ch 32bits Integer, 8 bytes per frame 44.1kHz
Sample rate switching latency: 1s
Selected device:ASIO MADIface USB
Manufacturer:
Model name: ASIO MADIface USB
Model UID: ASIO MADIface USB
13 available sample rates up to 11289600Hz
2822400
5644800
11289600
Raw DSD (msb)
Device #0: ASIO MADIface USB
Manufacturer:
Chromecast devices found : 1
Device #0: XXXXX
Model name: xxxxxx
