No “Sort also Manual Playlists” was NOT enabled. But after enabling it, still the columns are not sortable. So this is not a resolution.
Please re-review my original submission. It would appears that it’s a bug. And if it’s not a bug, then it’s a UX issue. The control shouldn’t be displayed if it’s inoperable.
I was testing this a bit yesterday.
When you go to a single album and click on the column titles the up and down arrows change direction but nothing happens.
There are also some display issues with the arrows.
The if you go to a track listing via some other means sorting works.
Hello @peterluttrell, can you send us a mail at support@audirvana.com? Could you please sens us your playlist in it? We would also like to have your database, we will send you a link for that in response of your mail.
