I ran a test in six takes with two sets of settings using the same one-minute music sample as follows (N.B. no Jitterbug nor DragonTail used):
MBP to Meridian to Audiolab
#1, #3 (five clicks the same minute)
MBP to Meridian direct headphones
#2 (three clicks the same minute)
#4 (five soft clicks or wobbles the same minute)
MBP to non-MQA-AudiolabCD-usb to Meridian/AudiolabAmp
#5, #6 (zero clicks or wobbles the same minute). This gives better audio than CD and no clicks, whereas with direct Meridian the audio is far superior but marred with clicks…
Downloaded FLAC files return the same fault patterns as the MQA files (with a different FLAC music sample), though somewhat less obtrusively but to an extent that listening to CDs would be preferred.
TAKE 1 and 3 (remaining data to follow this message):
Registered to Raymond Lawrence Lokker
AUTO: /Users/raymond/Music
iTunes/Music library synchronization: last synchronized on Wed Dec 30 22:48:12 2020
Library database path: /Users/raymond/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 8036MB
Exclusive access: Disabled
Integer mode: Disabled
Prime Headphone Amp Output
Model UID:Prime Headphone Amp:1CBA:001F
UID:AppleUSBAudioEngine:Meridian:Prime Headphone Amp:FACTORY :1
ID 0x88 Prime Headphone Amp Output Manufacturer:Meridian
Model UID:Prime Headphone Amp:1CBA:001F UID:AppleUSBAudioEngine:Meridian:Prime Headphone Amp:FACTORY :1
Stream ID 0x89 2 channels starting at 1
18 virtual formats:
24 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:94 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x88 Prime Headphone Amp Output Manufacturer: Meridian Model UID: Prime Headphone Amp:1CBA:001F UID: AppleUSBAudioEngine:Meridian:Prime Headphone Amp:FACTORY :1
UPnP not started
TAKE 3:
Active Sample Rate: 96kHz
ID 0x58 Prime Headphone Amp Output Manufacturer:Meridian
Stream ID 0x59 2 channels starting at 1
18 virtual formats:
24 physical formats
Device #1: ID 0x58 Prime Headphone Amp Output Manufacturer: Meridian Model UID: Prime Headphone Amp:1CBA:001F UID: AppleUSBAudioEngine:Meridian:Prime Headphone Amp:FACTORY :1
UPnP not started
