Hello - I play DSD files form my local SSD drive win win10 NUC - into Chord Quest DAC.
Most of the songs (DSF files or ISO ) sounds good,
But on some songs - there are audible click’s or muffle weird sound ALONG the music.
When I check the same files with the same hardware - but switching from Audirvana to foobar2000 player - All Sound good.
Two “problematic” songs for you to test :
Here is my log file
Audirvana 3.5.46
AUTO: D:\FLAC-NUC
Library database path: D:\Audirvana_DB\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 892MB
Local Audio Engine:WASAPI
Digital Output (Chord Async USB 44.1kHz-768kHz)
Model UID:Digital Output (Chord Async USB 44.1kHz-768kHz)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{cc6bbca4-282f-4fed-a882-15a7321a43b2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
LG TV (Intel(R) Display Audio) Manufacturer:
Model UID:LG TV (Intel(R) Display Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{374d9852-6f61-4471-b6ee-8243a8905086}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: LG TV (Intel(R) Display Audio) Manufacturer: Model UID: LG TV (Intel(R) Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{374d9852-6f61-4471-b6ee-8243a8905086}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0[LG] webOS TV OLED55C9PVA UID: uuid:3236de85-fe8f-ab64-1372-0018437ad210 Location: http://10.0.0.48:1506/
