Sound settings
So if I set up Audirvana on my windows 11 laptop do I need to bother with the laptop’s sound settings like bit stream rates etc?. I was under the impression that Audirvana would supplant the laptop’s sound settings…yes?
Yes. Audirvana will make a direct (exclusive) connection to your DAC (internal or external) and bypass all of the Windows sound processing.
