Hi. I am running latest Audirvana on headless MINI with 10.13.6. I either stream or play from drive on MINI. Recently Audirvana has started to mute playback at start of playing a track. If I unmute it may stay unmuted for the next track but it will revert at the start of a new track. There is no consistency I can spot. There have been no changes to the MINI or to Audirvana. I seem to remember reading that someone else had this problem but a search here revealed nothing. Before I start to tear it all apart, could I ask if this has come up before? Thanks. Drew
Hello @drewR, Can you send me a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
Mute During Sample Rate Change could be a reason why it does not mute for every track but it does not explain why it plays in mute mode after.
Here is the debug info:
macOS 10.13.3 with 8192MB RAM
Registered to Andrew Rodger
Per track: OFF
Phase = 63
Replay Gain: by album
Sync list: 2 folders
AUTO: /Users/arodger/Music/Serious music
AUTO: /Users/arodger/Music/iTunes/iTunes Media/Music
Library database path: /Users/arodger/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4096MB
GOLDENOTE USB HD-DAC
Model UID:GOLDENOTE USB HD-DAC:20B1:0002
UID:AppleUSBAudioEngine:GOLDENOTE :GOLDENOTE USB HD-DAC:0000:1,2
Active Sample Rate: 192kHz
Sample rate switching latency: 2s
ID 0x3a GOLDENOTE USB HD-DAC Manufacturer:GOLDENOTE
Model UID:GOLDENOTE USB HD-DAC:20B1:0002 UID:AppleUSBAudioEngine:GOLDENOTE :GOLDENOTE USB HD-DAC:0000:1,2
Stream ID 0x3b 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x33 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3a GOLDENOTE USB HD-DAC Manufacturer: GOLDENOTE Model UID: GOLDENOTE USB HD-DAC:20B1:0002 UID: AppleUSBAudioEngine:GOLDENOTE :GOLDENOTE USB HD-DAC:0000:1,2
My hardware is currently a mid 2011 Mac Mini running Mac OS 10.13.6, which may be the OS ceiling for that unit. The Audirvana version is 3.5.38. The internet line speed is 10MBps.
Hi Damien
I undid the option to mute the switch of sample rate and it seems to have sorted the problem. I engaged the option because, in the past, a change to the rate would invoke a nasty noise but that does not seem to occur anymore so I think it is “problem solved”. Useful feedback though, I hope.
Cheers
Drew
