Static on DSD playback
I notice a staticky click before a track plays when changing to and from DSD to anything that is not DSD and sometimes between DSD tracks consecutively. I have tried this with DSD Over PCM 1.0 and 1.1 with same static.
I am still not sure if there is a better sound if I just use None: Convert to PCM … which seems to sound a bit warmer.
Solution re sound warm: DSD does not use EQ.
Sometimes it is quite loud…not enough to ruin speakers but a very distinct staticky interferance sound for a second or so.
This is not a terrible thing but reported in the interest of making /audirvana extremely more wonderful and to allow perfectionists to use it.
Still fantastic sound when listening to the music.
Regards
Phil
HERE IS THE DEBUG:
Audirvana Origin 2.5.19 (20520)
macOS Version 15.2 (Build 24C101) ARM64 with 8GB physical RAM
Connected account of : XXXXXXX XXXXXX
Local network access: allowed
Effects plugins ACTIVE in realtime mode with legacy macOS API
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
r8brain custom frequencies
384000Hz → 352800Hz
Sync list: 2 folders
AUTO: /Volumes/MusicSSDT7/AO-SSD-Music-T7
AUTO: /Volumes/MusicSSDT9/AO-SSD-Music-T9
Sort and display order: en
Library database path: /Users/philipjohnson/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 63206
Font size: large
Library
My Music
Startup view: Library: Albums
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: yes
Max. memory for audio buffers: 2066MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
PS Audio PS Audio USB Audio 2.0 Output
Model UID:PS Audio USB Audio 2.0:2616:0110
UID:AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:2400000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Selected device:PS Audio USB Audio 2.0 Output
Manufacturer: PS Audio
Model name: PS Audio USB Audio 2.0 Output
Model UID: PS Audio USB Audio 2.0:2616:0110
UID: AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:2400000:1
USB Vendor ID: 0x2616
USB Product ID: 0x0110
ID 0x4e
7 available sample rates up to 352800Hz
Max volume alert: Disabled
DSD via PCM 1.0
Stream ID 0x4f 2 channels starting at 1
21 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
28 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Device #0: ID 0x4e PS Audio USB Audio 2.0 Output
Device #1: ID 0x48 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Wi-Fi
UPnP devices found : 1
Device #0: ID 0x0 : BRAVIA KDL-32EX720
UID: uuid:00000000-0000-1010-8000-4CE676BC4AD6
Manufacturer: Sony Corporation
Model name: KDL-32EX720
Chromecast not started
First… I suggest using ‘Power of Two’ up-sampling of PCM files, and using DoP1.1 to deliver the DSD64 and DSD128 files (2.8MHz and 5.6MHz) because In the case of your PS Audio DAC these are handled by the DAC architecture, where all PCM signals are modulated to 1-bit PDM and all 1-bit PDM signals are handled natively… ‘Power of Two’ will correctly up-sample all of the different PCM sample-rates.
The nature of the “pop”, “click”, “tick”, “static” when changing sample-rate or format between PCM and DSD files is due to mastering of the 1-bit file which if not carefully edited will leave a sample or a few samples not at zero amplitude at the beginning or end of the file… So when the playback is initiated, the transition from either zero or some level above zero when the format is changed, will precipitate noise as the encoded signal jumps to zero or to the encoded sample amplitude. Typically this is handled in the DAC, however you can inject sample-rate switching latency so to give the signal, time to resolve to zero in Audirvāna.
Some food for thought…You could experiment with modulating all PCM files to DSD128 to see if the offloading of the conversion DSP to Audirvāna, makes some tangible improvement in the sound-quality you perceive… Or don’t convert any PCM files and let the DAC do all of the work…
You may try incrementally increasing or reducing the playback pre-load memory allocation to see if this makes a difference in the “static”.
