Still a little buggy after a 36 hr reinstall
For you Sound Engineers:
Audirvana Origin 2.5.13 (20513)
macOS 14.6.1 with 8GB physical RAM
Connected account of : M
	Globally: ON
Max allowed volume: 0.24383
Sync list: 5 folders
AUTO: /Volumes/2xDSD_MUSIC/
AUTO: /Volumes/16BIT_MUSIC/
AUTO: /Volumes/24BIT_MUSIC/
AUTO: /Volumes/DSD_MUSIC/
AUTO: /Volumes/U16BIT_MUSIC/
Library database path: /Users/masonsmacmini/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 60139
Font size: regular
Language: English
My Music
Library
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] H390D44134 Model UID:Hegel H390 UID:uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
Currently playing to UPnP device at 24 bits 176.4kHz
Selected device:H390D44134
Manufacturer: Hegel
Model name: H390
Model UID: Hegel H390
UID: uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
UPnP device at http://192.168.10.128:38400/description.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
Not automatically detected, user set to MQA Decoder
DSD via PCM 1.0 (Not sure of this setting) Current playing DSD 64 on DAC
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:05:18.000
CurrentURI: http://192.168.10.118:49152/audirvana/audio_f_83.wav
CurrentURIMetadata:
dc:titleDigging In The Dirt</dc:title>
dc:creatorPeter Gabriel</dc:creator>
upnp:artistPeter Gabriel</upnp:artist>
upnp:genreRock</upnp:genre>
upnp:albumArtURIhttp://192.168.10.118:49152/audirvana/artwork_0_83.jpg</upnp:albumArtURI>
upnp:albumUs [DSD]</upnp:album>
upnp:originalTrackNumber7</upnp:originalTrackNumber>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Seek,X_DLNA_SeekTime
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H390D44134 Hegel http://www.hegel.com H390 H390 1.0 http://www.hegel.com uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da http://192.168.10.128 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.10.128:38400
UPnP devices found : 1
Device #0: ID 0x0 : H390D44134
Manufacturer: Hegel
Model name: H390
Max. memory for audio buffers: 2512MB
Local Audio Engine: CoreAudio
Device #0: ID 0x32 LG FULL HD
Manufacturer: GSM
Model UID: 1E6D555B-0000-0000-011A-010380301B78
Model name: GSM LG FULL HD
Device #1: ID 0x58 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Had a wee bit of a crackle noise on the highs freq., Hi res file.
It appears H390 supports DSD via DoP on the USB bus but not via UPnP… The DoP PCM carrier for DSD64 (2.8MHz) is 24/176.4kHz… It is unclear, however, it seems the Hegel is trying to play the DSD carrier file…
if this is the case, you will need to convert DSD to PCM for UPnP playback… When the DSD file is decimated to PCM you may need to lower the output gain to -6db.
