Stop and go when streaming via Chromecast
I couldn’t correctly stream 24b/96kHz tracks to my Naim Uniti using Chromecast whereas I have no problem with UPNP on the same device : music just stops and go, as if the network throughput was insufficient, which is not case, I can stream up to 24/352 on the same device. I have no other devices supporting Chromecast to do other tests.
Hello @al1h,
With Chromecast, music plays a few seconds, then plays again, and so on…
Audirvana Studio 1.99.15 (19915)
Windows 11 (22000) with 16GB physical RAM
Connected account of : Alain Hafner
Replay Gain: by album
SW volume control: ON
Sync list: 3 folders
AUTO: E:\ahafn\Music
AUTO: E:\ahafn\Music_NEW__iTunes Music\Ahmad Jamal
AUTO: E:\ahafn\Music_NEW__qobuz
Library database path: C:\Users\ahafn\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:cb04:aa9:8000:4d3:4a30:352f:cb05 on port 61540
Active method: Chromecast
Preferred device: [Chromecast] Naim Salon
Model UID:Uniti Atom
UID:DnsSd#Uniti-Atom-60701fdba5588f03f6d1839c42c4322d._googlecast._tcp.local#0
Selected device: Naim Salon
Manufacturer:
Model name: Uniti Atom
Model UID: Uniti Atom
UID: DnsSd#Uniti-Atom-60701fdba5588f03f6d1839c42c4322d._googlecast._tcp.local#0
Volume control: Yes
Override device declared HiRes capability: OFF
Chromecast devices found : 1
Device #0: Naim Salon
Max. memory for audio buffers: 6088MB
Local Audio Engine: ASIO 0
Driver version 0
Local devices found : 3
Device #0: Denon ASIO Device
Manufacturer:
Model UID: Denon ASIO Device
Model name: Denon ASIO Device
Device #1: Encore ASIO Driver
Manufacturer:
Model UID: Encore ASIO Driver
Model name: Encore ASIO Driver
Device #2: FiiO ASIO Driver
Manufacturer:
Model UID: FiiO ASIO Driver
Model name: FiiO ASIO Driver\nnUPnP
UPnP devices found : 2
UID: uuid:9ef316c9-787f-4952-9bca-62cfdeda8b01
Location: http://192.168.1.19:59486/9ef316c9-787f-4952-9bca-62cfdeda8b01.xml
Manufacturer: Naim Audio
Device #1: Décodeur TV
UID: uuid:00ababad-7947-1048-8a00-247f20e82e0d
Manufacturer: SoftAtHome
Model name: SoftAtHome Media Renderer
to be precise, with UPNP, I can stream only up to 192 kHz or DSD 128, because my NAIM Uniti Atom does not support higher rates, which are down-sampled by Audirvana Studio
