Hello,
I have updated my Lumin U2 to version 18.0b and AS to version 2.9.4.
Often, the playback stop at the end of a track instead of switch to the next one.
My debug info:
Audirvana Studio 2.9.4 (20904)
Windows 11 (22631) x86_64 with 16GB physical RAM
Connected account of : xxxx
Available network interfaces:
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Sync list: 0 folders
Library database path: C:\Users\raifer\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 670
Listening on 192.168.1.15 on port 54818
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 2
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] LUMIN U2:LUMIN Model UID:Pixel Magic Systems Ltd. U2 UID:uuid:4c494e4e-3d9b-11e1-b86c-000bdfb023fa
Currently playing to UPnP device at 32 bits 44.1kHz
Selected device:LUMIN U2:LUMIN
Manufacturer: Pixel Magic Systems Ltd.
Model name: U2
Model UID: Pixel Magic Systems Ltd. U2
UID: uuid:4c494e4e-3d9b-11e1-b86c-000bdfb023fa
UPnP device at http://192.168.1.31:23000/
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
http-get:::*
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp4:
http-get::audio/mpeg4-generic:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aac:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/octet-stream:
http-get::audio/opus:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB (-90dB to 0dB)
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 32bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
2 ch Integer PCM 32bit little endian 768kHz finite length
2 ch DSD 8bit little endian in 8bit chunk 22579.2kHz finite length
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI: qobuz://track?version=2&trackId=277462891
CurrentURIMetadata: dc:titlePrélude in D Major</dc:title>dc:creatorUnknown</dc:creator>dc:date2024-09-26</dc:date>upnp:artistSophie de Bardonnèche</upnp:artist>upnp:albumDestinées</upnp:album>upnp:genreClassique</upnp:genre>upnp:albumArtURIhttps://static.qobuz.com/images/covers/kc/no/d7o3har14nokc_600.jpg</upnp:albumArtURI>upnp:originalTrackNumber11</upnp:originalTrackNumber>qobuz://track?version=2&trackId=277462891upnp:classobject.item.audioItem.musicTrack</upnp:class>
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Play,Pause,Stop,Seek,Next,Previous
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 LUMIN U2:LUMIN Pixel Magic Systems Ltd. https://www.luminmusic.com/ LUMIN U2 1.0 https://www.luminmusic.com/ uuid:4c494e4e-3d9b-11e1-b86c-000bdfb023fa QPlay:2 DMR-1.50 image/png 120 120 24 /images/lumin-120x120.png image/png 48 48 24 /images/lumin-48x48.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /Product/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Product/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Product/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /Playlist/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Playlist/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Playlist/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /Time/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Time/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Time/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /Info/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Info/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Info/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /Volume/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Volume/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Volume/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Transport:1 urn:av-openhome-org:serviceId:Transport /Transport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Transport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Transport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:magictv-com:service:MagicAudio:1 urn:magictv-com:serviceId:MagicAudio /MagicAudio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /Credentials/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Credentials/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Credentials/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /Radio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Radio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Radio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /Receiver/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Receiver/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Receiver/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:schemas-tencent-com:service:QPlay:2 urn:tencent-com:serviceId:QPlay /QPlay/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /QPlay/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /QPlay/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:luminmusic-com:service:KKBoxService:1 urn:luminmusic-com:serviceId:KKBoxService /KKBoxService/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /KKBoxService/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /KKBoxService/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xmlCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 LUMIN U2:LUMIN Pixel Magic Systems Ltd. https://www.luminmusic.com/ LUMIN U2 1.0 https://www.luminmusic.com/ uuid:4c494e4e-3d9b-11e1-b86c-000bdfb023fa QPlay:2 DMR-1.50 image/png 120 120 24 /images/lumin-120x120.png image/png 48 48 24 /images/lumin-48x48.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /Product/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Product/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Product/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /Playlist/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Playlist/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Playlist/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /Time/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Time/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Time/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /Info/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Info/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Info/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /Volume/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Volume/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Volume/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Transport:1 urn:av-openhome-org:serviceId:Transport /Transport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Transport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Transport/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:magictv-com:service:MagicAudio:1 urn:magictv-com:serviceId:MagicAudio /MagicAudio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /Credentials/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Credentials/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Credentials/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /Radio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Radio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Radio/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /Receiver/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /Receiver/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /Receiver/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:schemas-tencent-com:service:QPlay:2 urn:tencent-com:serviceId:QPlay /QPlay/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /QPlay/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /QPlay/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xml urn:luminmusic-com:service:KKBoxService:1 urn:luminmusic-com:serviceId:KKBoxService /KKBoxService/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/scpd.xml /KKBoxService/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/control.xml /KKBoxService/4c494e4e-3d9b-11e1-b86c-000bdfb023fa/event.xmlUPnP devices found : 1
Device #0: LUMIN U2:LUMIN
Model name: U2
Max. memory for audio buffers: 8192MB
Local Audio Engine: WASAPI
Device #0: Speaker/HP (Realtek High Definition Audio(SST))
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0285&SUBSYS_17AA225C&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{57779e52-475f-4e70-8dbe-47f19eb3374d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
My log:
2024-11-17 19:45:21.304 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462884 for new AVTransportURI
2024-11-17 19:48:42.986 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462885 for new AVTransportURI
2024-11-17 19:51:50.640 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462886 for new AVTransportURI
2024-11-17 20:02:57.962 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462887 for new AVTransportURI
2024-11-17 20:06:28.999 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462888 for new AVTransportURI
2024-11-17 20:27:13.820 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462889 for new AVTransportURI
2024-11-17 20:30:27.595 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462890 for new AVTransportURI
2024-11-17 20:46:56.975 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462891 for new AVTransportURI
Bonjour @HTox ,
Est-ce que le problème est présent avec n’importe quelle playlist Qobuz?
Bonjour @Antoine, le problème survient aussi à la lectures des pistes d’un album ou lors de la lecture automatique après la fin d’un album. Pour le moment, cela semble totalement aléatoire!
Le problème vient de se reproduire et j’était sur l’application remote, j’ai quelques info en plus à partager.
Cette fois si la lecture c’est stoppé à la fin d’un Album. L’album en question contient 10 pistes. La lecture aurait du continuer sur des pistes sélectionné automatiquement.
Info intéressante: J’ai pu observer la lecture de cette dernière piste avec l’application remote, la barre de progression de lecture est restée bloqué à 0. J’ai quand même pu modifier le volume sans problème.
Les nouveaux logs:
2024-11-18 13:32:37.789 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=277462892 for new AVTransportURI
Pouvez-vous me dire le nom de l’album pour que j’essaie de tester avec l’appareil Lumin que j’ai?
Je viens de relancer le même album et cette fois ci cela à continué normalement après la dernière piste. Là cela tourne depuis 3 heures sans problème.
L’album était “Got To Be There” de Michael Jackson.
Pourrions-nous immaginé un monde ou la perte d’un paquet réseau pourrait provoquer ce type de problème? Mon ordi est connecté en Wifi à une distance de 2 mettres de ma box. Le Lumin U2 est connecté en Ethernet avec un bon cable réseau.
J’imagine que les data audio sont envoyé avec de l’UDP, je ne sais pas si les metadata utilise un autre protocole!
I reproduced my issue with another PC connected via Ethernet : Linux Fedora with the same version of AS.
Peter have send me another Firmware version 18.0e which was tested with Antoine. I will test it tonight!
How does the new firmware work? Are the problems with some times not skipping to the next track gone?
I have an U1 and there are still problems with the current 18.0 firmware and the latest Audirvana Studio release. Allthough the U1 is certified as a Play with Audirvana device since some days it does not work which makes me ask myself what the certification is for. I do not want to say that the problem is related to Audirvana because the U1 has been worked perfectly with all firmwares before, so there defenatly there must be something wrong with the current 18.0 firmware. But, on the other hand, why are the devices from Lumin certified if they do not work properly?
Hmm, lets hope that this certification will help to solve the problems quickly.
I think that the problem is still present with 18.0e. To be sure, I will perform some additional tests during this week-end. I’ll post news quickly.
Unfortunately I confirm that the issue is still present.
Find bellow the last log:
2024-11-29 22:40:57.052 [info]: ============= Started Logging, Audirvana Studio 2.9.4 Linux x86_64 =============
2024-11-29 22:40:57.055 [info]: Running on Linux 6.11.8-300.fc41.x86_64 x86_64
2024-11-29 22:40:57.057 [info]: No language set in settings, using system language: en_US.UTF-8
2024-11-29 22:40:57.140 [info]: Entering offline mode
2024-11-29 22:40:57.448 [error]: HTTP request error (6) Could not resolve host: static.qobuz.com for URL https://static.qobuz.com/images/covers/3a/x7/uojji2qdkx73a_600.jpg
2024-11-29 22:40:57.448 [error]: HTTP request error (6) Could not resolve host: static.qobuz.com for URL https://static.qobuz.com/images/covers/63/56/0887828035663_600.jpg
2024-11-29 22:40:57.475 [critical]: UPnP Unable to initialize UPnP stack at all: no network interface
2024-11-29 22:40:57.476 [error]: HTTP request error (6) Could not resolve host: static.qobuz.com for URL https://static.qobuz.com/images/covers/63/56/0887828035663_600.jpg
2024-11-29 22:40:57.492 [error]: HTTP request error (6) Could not resolve host: static.qobuz.com for URL https://static.qobuz.com/images/covers/63/56/0887828035663_600.jpg
2024-11-29 22:40:57.575 [info]: Local Library Sync: inotify max_user_watches is set to 374665
2024-11-29 22:40:57.576 [error]: HTTP request error (6) Could not resolve host: static.qobuz.com for URL https://static.qobuz.com/images/covers/63/56/0887828035663_600.jpg
2024-11-29 22:40:57.782 [info]: RemoteServer: Server started and advertised on port 41563
2024-11-29 22:41:01.982 [info]: Network is up again, checking Internet access…
2024-11-29 22:41:01.983 [error]: Failed to resolve internet address
2024-11-29 22:41:01.983 [info]: Checking Internet connection: ping failed 1/100
2024-11-29 22:41:05.161 [info]: Internet access is available
2024-11-29 22:41:05.161 [info]: Network is back online: trying to reconnect to Audirvana account
2024-11-29 22:41:06.281 [info]: UPnP stack initialized using default interface
2024-11-29 22:41:06.482 [info]: UPnP web server started on 192.168.1.200:49152
2024-11-29 22:58:07.347 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695829 for new AVTransportURI
2024-11-29 23:08:09.569 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695830 for new AVTransportURI
2024-11-29 23:10:52.634 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695831 for new AVTransportURI
2024-11-29 23:14:19.166 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695832 for new AVTransportURI
2024-11-29 23:17:41.779 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695833 for new AVTransportURI
2024-11-29 23:20:53.541 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695834 for new AVTransportURI
2024-11-29 23:25:16.114 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695835 for new AVTransportURI
2024-11-29 23:31:08.350 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695836 for new AVTransportURI
2024-11-29 23:40:06.612 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695837 for new AVTransportURI
2024-11-29 23:43:20.022 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695838 for new AVTransportURI
2024-11-29 23:47:13.340 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695839 for new AVTransportURI
2024-11-30 00:06:03.915 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695840 for new AVTransportURI
2024-11-30 00:09:56.163 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695841 for new AVTransportURI
2024-11-30 00:17:56.138 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695842 for new AVTransportURI
2024-11-30 00:20:28.579 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695843 for new AVTransportURI
2024-11-30 00:28:09.188 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695844 for new AVTransportURI
2024-11-30 00:33:39.608 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695845 for new AVTransportURI
2024-11-30 00:38:13.928 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695846 for new AVTransportURI
2024-11-30 00:44:50.338 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695847 for new AVTransportURI
2024-11-30 00:48:09.129 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695848 for new AVTransportURI
2024-11-30 00:57:08.286 [error]: UPnP AVTransport event: can’t parse filename qobuz://track?version=2&trackId=17695849 for new AVTransportURI
2024-11-30 10:49:30.492 [error]: Remote: event websocket lost with error: Connection reset by peer
@Antoine, what is the next step? How I can help you to debug?
I will ask Lumin to send me the firmware you have, so I can try reproduce your issue. I will try my best to do it this week.
Got a new firmware for my Lumin U1 a few days ago, version 18.0a or something like that. Unfortunately the problem is still there and sometimes skipping to the next track does not work.
Just waiting a few minutes without touching Audirvana or the streamer and for what reason ever the playback is continuing either with the same track played recently or with a track before ;-).
My Lumin U2 is on sale!
If the issue is fixed I’ll maybe keep it.
What streamer will you buy if you not longer have the U2? I’ll keep my U1 for sure, but its really sad that Audirvana and the streamer do not longer work together perfectly like it was in the past. I’ll use the Lumin app allthough I think music sounds better with Audirvana. and I have some other alternatives to stream with Audirvana, have an old SMS 200 from SOTM and a streaming bridge in my MSB DAC that I can use instead.
But like said in a earlier post: I do not understand how Lumin can be a certified Plays with Audirvana partner if those problems exist for such a long time. Its not the fact that there is a problem. Problems can occure, no question. But its really a shame that no fix or workaround is provided for such a long time, no matter if the fix has to be made by Lumin or Audirvana. Its really disapointing :-(.
I have also a 3D Lab player that work correctly except for radio, I have to open a post about that ;).
I think that the UPnP connexion is not reliable and it is difficult to implement correctly with severals brants.
My problem is solved. I sold my Lumin U2!
Too bad the UPnP protocol so difficult to implemente and debug.
FYI, I installed the last firmware 18.1 and the problem is worse than before!
I’ve tested my U1 with the firmware 18.1, 18.0 and also the latest 17.x firmware which I got from Lumin. All with the current 2.9.5 Audirvana Studio version.
No of those firmwares worked with Audirvana allthough I am sure that all was fine with 17.x.
I will downgrade Audirvana also to older versions to see if the problem is really related to the firmware or maybe to Audirvana.
Not sure what I should think. Audirvana says it is related to firmware, Lumin says nothing really helpfull, just provided me the older firmware which also does not work anymore.
Its really sad. @antoine: Can you tell the current state? Is work on this problem in progress and is there a timeline where we can hope the problems are fixed?
