Dear all,
Looking at the error messages on Console on my MAC, I discovered some errors on some audio files that say:
Error opening the FLAC file for decoding: file=file://%2FVolumes%2FAudio2%2Frock%2F1001%20Albums%20You%20Must%20Hear%20Before%20You%20Die%20%28vol.I%29%2F0066.%20The%20Kinks%20-%20Face%20To%20Face%20%281966%29%2FThe%20Kinks%20-%20Face%20To%20Face.flac error = 4
That’s pretty strange! I tried to play the audio files in that very same directory, and it works. I don’t know what is error 4 and I did not see any clear impact on the import process.
File name decoded = /Volumes /Audio2 /rock /1001 Albums You Must Hear Before You Die (vol.I ) /0066. The Kinks - Face To Face (1966 ) /The Kinks - Face To Face.flac error = 4
FYI, there is no such Flac file, only a CUE file. Is that possible that AS mixes Flac and CUE files?
Good point Jakob.
Indeed, the CUE file makes reference to a FLAC file with the same name (“The Kinks - Face To Face.flac”), which does not exist. Maybe here it is an old cue file created at the time where the entire album was included into one single FLAC file.
I need to clean up that mess…
Eric
