Hi
Legacy version with Tidal/Quboz loaded. Quboz working ok. Tidal some tracks get stuck at “loading first track” and then dozens of tracks get skipped till eventually a track down the list plays skipping dozens of tracks in the process.
Playing on Mac mini to Mscaler.
Used to work fine but this issue plaguing recently.
Debug info below. Same issue outputting to Wiim mini and all outputs.
macOS 12.7.6 with 16384MB RAM
Registered to aroosh naqvi
Max allowed volume: 83.4757
AUTO: /Users/arooshnaqvi/Desktop/music
Library database path: /Users/arooshnaqvi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as PREMIUM
Exclusive access: Disabled
Mscaler
Model UID:Mscaler:245F:0815
UID:AppleUSBAudioEngine:Chord Electronics Ltd:Mscaler:413-001:2
ID 0x50 Mscaler Manufacturer:Chord Electronics Ltd
Model UID:Mscaler:245F:0815 UID:AppleUSBAudioEngine:Chord Electronics Ltd:Mscaler:413-001:2
11 available sample rates up to 768000Hz
32000
Stream ID 0x51 2 channels starting at 1
22 virtual formats:
22 physical formats
Local devices found : 3
Device #0: ID 0x2b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3a HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{6D1E-0001-01010101}
Device #2: ID 0x50 Mscaler Manufacturer: Chord Electronics Ltd Model UID: Mscaler:245F:0815 UID: AppleUSBAudioEngine:Chord Electronics Ltd:Mscaler:413-001:2
UPnP devices found : 2
Device #0: ID 0x0 WiiM Pro AN UID: uuid:FF98F09C-B197-57FE-E5BC-A46AFF98F09C Location: http://192.168.1.123:49152/description.xml
Device #1: ID 0x0 [LG] webOS TV NANO796QA UID: uuid:52aa3854-b1be-115f-2fac-c9410781633b Location: http://192.168.1.37:1803/
