Sometimes the volume slider is stuck. The slider shows the same value numerically and visually , but it works functionally, I can change the volume. (I have to restart the application and then it works again correctly)
My other problem is that the placement of the iPad’s volume is life-threatening for the loudspeakers because can accidentally touch it, so there should be some kind of locking option for this .
