After updating audirvana to the latest version im not able to start the app anymore, i uninstalled / repaired / reset but has not worked …
Are you sure you are not starting Audirvana with an old shortcut? Updates/Installations from the Microsoft store don’t always land in the same directory. If you have a shortcut pinned to the task bar it is probably still pointing to the old path. Try starting Studio from the Windows start menu. If that works you can always pin that again to the task bar.
If this does not apply to you or if you already have done all this, please consider this post as not applicable
