It appears that Studio is loading offline only. After app restarts and system restarts, all I get is offline mode.
Me too
Same for me today
Hi guys, do you still get the issue after restarting Audirvāna Studio?
Same for me , will start in offline only , then say’s " my subscription is expired" which isn’t the case
Are they hacked?
Down for me as well and have tried to restart 2 x. Qobuz is up and running FYY…
No problem here (Netherlands) Audirvana Studio on Windows.
Online and Qobuz works fine (within Studio).
Yes, still “disconnected” after restarting computer and Studio twice each
Ok, we are on this, will update you ASAP.
I am in France. Tidal works fine, as well as Audirvana 3.5. Do you need the debug info, Antoine ?
I don’t think so, but I will update you if it’s needed.
Yes, after restarting computer and Studio several times, still “disconnected”
toujours le même problème
Back up and running…thx for fast resolution!
Please restart Audirvāna Studio and the issue should be sorted.
We made some security improvements on the back-end of Audirvāna regarding TLS but now it should be sorted.
Yes, solved! Congratulations
Issue resolved. Thank you…
