When playing Qobuz playlists, there is a one second stutter between tracks. The next track starts for one second, then repeats the beginning of the song before playing selection. Any suggestions are welcome. Once song gets going, the playback is flawless. This happens between every subsequent track.
Still getting stuttering between tracks in Playlists. Tried every suggestion in forum except reducing number of buffers in audio section. That suggestion must be from a previous version as I can find no audio section to reduce buffers in. I also don’t see a menu at the t top of the screen in version 5.3.5.
I’m using a 64 bit Windows 10 rig with 32 Gig of RAM and a R.A.I.D. aray of four 500 Gig Solid State Drives with an I7 Intel processor and I am hard wired directly to my router.
I thought the problem was Qobuz but I created a smart Playlist from my drives and still, stuttering of one second between tracks. I’m connected to my 65" Samsung TV. Gonna try conecting directly to my AVR (Denon AVR X4500H) and see if problem still persists. If so, I may not survive the trial period I am in It’s a shame. The sound quality is amazing and I like the idea of install EQ Plugins. Can anyone help?
Are you connecting using HDMI? Your setup is unfortunately not ideal for audio.
Thank you. I see what you mean. I will connect using HDMI to get better audio.
Problem solved. Connected directly to my AVR from PC as you suggested. Sound card doesn’t support bitrate/Khz but I have my eye on an Asus I like that does. Now if I can output video to my TV so people in room know what song/group is playing…
Same problem today: Scratchy stuttering between two tracks. Using Qobuz via Asus notebook, connected per USB-B with Lyngdorf TDAI 3400 as a streamer. Should be perfect for Audio. Any ideas?
Can you paste the debug info here?
How do I get that?
You can get it in Audirvana Settings>My account
Audirvana Studio 2.2.0 (20200)
Windows 10 (19044) with 8GB physical RAM
Connected account of : Bernd Matthies
Sync list: 3 folders
AUTO: C:\Users\bm\Downloads\HighResAudio.com
Manual: (OFFLINE) C:\Users\bm\Downloads\Stereo256\Stereo256
AUTO: C:\Users\bm\Music
Library database path: C:\Users\bm\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.178.25 on port 58603
Max. memory for audio buffers: 2184MB
Digitale Ausgabe (Lyngdorf Audio A/S USB Driver 1.0.57)
Model UID:USB\VID_16D0&PID_08FD&REV_0197
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{829383bd-def3-47c7-bd36-245853524786}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Digitale Ausgabe (Lyngdorf Audio A/S USB Driver 1.0.57)
Manufacturer: Lyngdorf Audio A/S
Model name: Lyngdorf Audio A/S
Model UID: USB\VID_16D0&PID_08FD&REV_0197
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{35664be5-eb89-4133-baed-6efc009e0bf3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x16d0
USB Product ID: 0x08fd
Kernel Streaming capable
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
Device #0: Digitale Ausgabe (Lyngdorf Audio A/S USB Driver 1.0.57)
Device #1: Speakers (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_10431CFD&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{37bfb2ec-741f-4608-bb2d-710de714f8f1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 3
Device #0: TV Wohnzimmer
UID: uuid:23456789-1234-1010-8000-70260549BF24
Location: http://192.168.178.23:52323/MediaRenderer.xml
Manufacturer: Sony Corporation
Model name: MediaRenderer
Device #1: Gabis Bose
UID: uuid:BO5EBO5E-F00D-F00D-FEED-F45EAB5E6BEE
Location: http://192.168.178.27:8091/XD/BO5EBO5E-F00D-F00D-FEED-F45EAB5E6BEE.xml
Manufacturer: Bose Corporation
Model name: SoundTouch 10
Device #2: TDAI-3400-7C6F80
UID: uuid:074dec55-7a52-4ae7-ab90-d631070f3aac
Location: http://192.168.178.24:44987/074dec55-7a52-4ae7-ab90-d631070f3aac.xml
Model name: TDAI-3400
Chromecast devices found : 1
Model name: BRAVIA 4K GB
Can you do the update to 2.2.1 and check if you have this issue with WASAPI? If it’s not the case, can you change your Kernel Streaming optimization setting from Extreme to Standard? This setting is in your audio output setting of Audirvāna Studio.
Seems to work. So how do I find the Kernel settings? On audio output settings is nothing like that.
When you click on the gear icon next to your device name, what do you see?
Nothing - except I go back from wasapi to kernel streaming before. But thanks, I hope it will work.
