YEs I just did, no change. Attaching the debug info…
Audirvana Mac Version 3.5.34 (3564)
macOS 10.15.4 with 8192MB RAM
Registered to Radovan Čechvala
Replay Gain: by track
Sync list: 2 folders
AUTO: /Volumes/My Book Duo/iTunes Media/HDtracks
AUTO: /Users/navodarc/Music/iTunes/iTunes Music
Library database path: /Users/navodarc/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
R3PRO
Model UID:R3PRO:C502:0061
UID:AppleUSBAudioEngine:HiBy:R3PRO:HiBy R3PRO:1
Active Sample Rate: 384kHz
ID 0x66 R3PRO Manufacturer:HiBy
Model UID:R3PRO:C502:0061 UID:AppleUSBAudioEngine:HiBy:R3PRO:HiBy R3PRO:1
32000
Audio buffer frame size : 116 to 4096 frames
Stream ID 0x67 2 channels starting at 1
36 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 32kHz
54 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 32kHz
Local devices found : 7
Device #0: ID 0x57 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:129 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x66 R3PRO Manufacturer: HiBy Model UID: R3PRO:C502:0061 UID: AppleUSBAudioEngine:HiBy:R3PRO:HiBy R3PRO:1
Device #2: ID 0x68 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Device #3: ID 0x44 Boom2Device Manufacturer: globaldelight Model UID: com_globaldelight_driver_Boom2Device:Boom2Device UID: Boom2Engine:0
Device #4: ID 0x31 BoomAudio Manufacturer: Global Delight Technologies Pvt. Ltd. Model UID: GDAudioDevice_ModelUID UID: GDAudioDevice_UID
Device #5: ID 0x39 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #6: ID 0x2c Squirrels Audio Manufacturer: Squirrels LLC. Model UID: com.squirrels.SquirrelsLoopbackAudioDriver UID: com.squirrels.SquirrelsLoopbackAudioDriver.Device
UPnP devices found : 2
Device #0: ID 0x0 KD-55XF8096 UID: uuid:23456789-1234-1010-8000-702605F88A1C Location: http://192.168.100.9:52323/MediaRenderer.xml
Device #1: ID 0x0 Three UID: uuid:00000000-0000-1010-8000-8c579bdef6fc Location: http://192.168.100.165:54380/MediaRenderer_SRS-ZR5.xml
