Switching from server to laptop problem
HI
when I switch from playing music from the server at home to the laptop, audirvana logs me out and asks me to log in again (enter the password). The server is not connected to the screen, so this is a big problem in using the program comfortably. Is there anything I should change in the settings? I am currently using the studio version. The previous version 3.x, which I used for many years, did not require logging in. I am considering buying Chord Poly, so this behavior of the program casts doubt on this purchase.
No, this is how it works. Whenever you switch from where you play, you have to disconnect and log in again. Both can be done from the same remote app. The remote app can also operate Audirvana on your laptop if both are in the same network.
