From the beginning of my using Audirvana (v2.0) syncing was great until recently (v2.2?). Now it never syncs unless I go to Settings>Local and manually start the sync. I have a decently fast computer but it is still a PITA to do.
Library is on a USB external drive.
M1 iMac
macOS Ventura 13.1
Audirvana 2.2.4
Debug:
Audirvana Studio 2.2.4 (20204)
macOS Version 13.1 (Build 22C65) with 16GB physical RAM
Connected account of : Tim Lance
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX with 2x upsampling
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/One/MUSIC
Library database path: /Users/me/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 55740
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Built-in Output
Model UID:
UID:
Active Sample Rate: 48kHz
Selected device:iMac Speakers
Model name: Apple Inc. iMac Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
ID 0x4e
Stream ID 0x4f 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x4e iMac Speakers
Model UID: Speaker
Device #1: ID 0x31 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
