For the last week, every time I use Audirvana, the SysOptimiser fails to load. The box opens saying SysOptimiser needs to install, still doesn’t work… even after restart.
I thought, and hoped, this issue had been solved.
Try trashing its preferences…
Close Audirvana.
Restart MAC.
Restart Audirvana, play a song… SysOpt will ask to install, and see
Thanks for the reminder… i have done this a while ago. SysOptimiser working correctly again.
Any idea why it corrupts?
Nope .
(Need 20 characters to post)
