System Optimizer stops with Tidal
New Studio account installed yesterday, along with a Tidal music account. I have no problem playing radios, but whenever I play Tidal music, the System Optimizer stops during buffering and “Exclusive audio access” is never engaged. I tried various setting with the same results. What am I missing?
Thanks a bunch.
Audirvana Studio 2.2.3 (20203)
macOS 10.13.6 with 16GB physical RAM
Connected account of : Dan Proulx
No plugin active
Sync list: 0 folders
Library database path: /Users/danproulx/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49188
TIDAL: Connected as
Max. memory for audio buffers: 11932MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
PS Audio PS Audio USB Audio 2.0
Model UID:PS Audio USB Audio 2.0:2616:0113
UID:AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:fd140000:1
Limit bitdepth to 24bit: ON
Selected device:PS Audio USB Audio 2.0
Manufacturer: PS Audio
Model name: PS Audio USB Audio 2.0
Model UID: PS Audio USB Audio 2.0:2616:0113
UID: AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:fd140000:1
USB Vendor ID: 0x2616
USB Product ID: 0x0113
ID 0xe7
Stream ID 0xe8 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 5
Device #0: ID 0xca Built-in Output
Model UID: AppleHDA:9
Device #1: ID 0xe7 PS Audio USB Audio 2.0
Device #2: ID 0x28 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Device #3: ID 0x31 Soundflower (2ch)
Manufacturer: ma++ ingalls for Cycling '74
Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower
UID: SoundflowerEngine:0
Model name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #4: ID 0x3c Soundflower (64ch)
UID: SoundflowerEngine:1
Model name: ma++ ingalls for Cycling '74 Soundflower (64ch)
Chromecast devices found : 5
Device #0: Stereo and Gazebo
Model name: Google Cast Group
Device #1: One
Device #2: Gazebo
Model name: Chromecast Audio
Device #3: Admin
Model name: Google Home Mini
Device #4: Mi Box
Model name: MIBOX3
Somewhat embarrassing but apparently I had not completed the Tidal registration which is why it wasn’t working. If I knew how to close or delete this post I would.
