TEAC HR can read DSF without DOP on mac, any hope for Audirvana?
Hello,
I’m using a TEAC UD-503 and I upsample everything to DSD 128 with very good results. It’s the max I can do with DOP, the max of the dac is DSD 256 that I can get booting my mac mini on windows. But I prefer the sound of MacOS.
I’ve tried TEAC-HR and surprise… It can read 256 DSF file on a my mac.
The file is 256, the TEAC show DSD 11.2M
Have they made a kind of ASIO for mac ?
Perhaps Damien Plisson can communicate with TEAC to integrate this tech ?
Can other TEAC DAC users confirm this ? Catalina 10.15.7 mac mini server 2012
Have you selected dop 1.1 in the settings of Audirvana?
Yes, DOP 1.1, but ther is no choice ā€œNo DOPā€ I can choose to test.
dop 1.0 can go to dsd128
dop 1.1 can go dsd256 on Mac
dop only on Mac…
maybe that TEAC HR have found something for Mac’s :slight_smile:
… but if your DAC can do DSD256… it should works with DOP 1.1
you unplug everything, did a restart of all?
Thank’s for your help. I’ve made another test : reading 32/705, and that doesn’t work either, The dac detect 352 one second and …nothing. I put in bold differences playing or stop. Is it normal that the frequency is the half when not playing ? Local audio engine can be something else than core audio ?
Playing tech log :
Audirvana Studio 2.9.4.1 (20905)
macOS 10.15.7 x86_64 with 16GB physical RAM
r8brain custom frequencies
44100Hz → 705600Hz
48000Hz → 705600Hz
88200Hz → 705600Hz
96000Hz → 705600Hz
176400Hz → 705600Hz
192000Hz → 705600Hz
352800Hz → 705600Hz
384000Hz → 705600Hz
Bandwidth = 97.8%
Phase minimum phase
SW volume control: ON
Listening on 127.0.0.1 on port 49739
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
TEAC Corporation TEAC USB AUDIO DEVICE
Model UID:TEAC USB AUDIO DEVICE:0644:8043
UID:AppleUSBAudioEngine:TEAC Corporation:UD-503:14400000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
Sample rate switching latency: 5s
Limit bitdepth to 24bit: ON
Selected device:TEAC USB AUDIO DEVICE
Manufacturer: TEAC Corporation
Model name: TEAC Corporation TEAC USB AUDIO DEVICE
Model UID: TEAC USB AUDIO DEVICE:0644:8043
UID: AppleUSBAudioEngine:TEAC Corporation:UD-503:14400000:1
USB Vendor ID: 0x0644
USB Product ID: 0x8043
ID 0x3c
9 available sample rates up to 705600Hz
Audio buffer frame size : 106 to 4096 frames
Max volume alert: Disabled
DSD via PCM 1.1
Stream ID 0x3d 2 channels starting at 1
36 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
54 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Local devices found : 3
Device #0: ID 0x37 Sortie intƩgrƩe
Model UID: AppleHDA:88
Model name: Apple Inc. Sortie intƩgrƩe
Device #1: ID 0x29 HDMI
UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-6804-01010101}
Model name: Apple Inc. HDMI
Device #2: ID 0x3c TEAC USB AUDIO DEVICE
non playing tech log
Bandwidth = 97.8%
Phase minimum phase
Listening on 127.0.0.1 on port 49889
extended in source list: no
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Integer mode: ON
Active Sample Rate: 352.8kHz
ID 0x3c
DSD via PCM 1.1
36 virtual formats:
54 physical formats
Another thing I want to check with you is that when Oversample show 64 bit, is that normal ?
Why does it matter? DSD over PCM (DoP) is a technology that transmits 1-bit PDM signal via a PCM file packetizing scheme… No data loss… The DoP processor of your DAC extracts the 1-bit PDM signal and presents it to the output circuitry…
In the context of your DAC, it supports an unfettered 1-bit PDM signal-path from the DoP extraction to output… there is no difference between a raw native 1-bit PDM (DSD) signal and the 1-bit PDM signal extracted from the DoP carrier.
Ethernet UPnP transmission from a Mac platform will deliver native 1-bit DSD signals to a DAC.
https://www.dsd-guide.com/dop-open-standard
Note: Your DAC supports up to DSD256 via DoP 1.1 as the PCM carrier sample-rate is 24/705.6kHz.
This is display represents the 64-bit math used in the Digital Signal Processing (DSP) calculations.
thank’s for your quick answer, What matter is that I can’t play 256 with my DAC. (nothing against DOP), just try to understand how to make it work. the DSD DOP use the 32 705.
but 32/705 doesn’t work.
If I can debug the 32 705 it will perhabs debug the DSD 256 ?
you said ā€œthe PCM carrier sample-rate is 24/705.6kHz.ā€
I tried to limit to 24bit, but tthe dac still receive 32 and no sound
DoP uses a 24bit header on the packet frames…
In your last post of your debug report, you are showing the active sample-rate as 352.8kHz which is the DoP carrier sample-rate for DSD128 (5.6Mhz)
Note: You are not modulating PCM files to DSD in r8Brain, you are just sending upsampled PCM signals to your DAC.
Yes, it’s when I don’t play. when I begin to play it switch to hog on and 705, but the dac is lost after the firs signal in 352
I tried to limit to 24bit the entry dac settings, but the dac still receive 32 and no sound
IF you are upsampling (modulating) PCM to DSD in r8Brain you must set it to ā€œDSDā€ and choose the target DSD sample-rate.
If you are just playing a .dsf file, r8Brain and any other DSP is bypassed. and will be delivered as a DoP signal.
OK back to DSD test.
nativ DSF from the lib. doesn’t work, as upsample. here is the log from a 256 DSF file in the lib.
r8brain to DSD256 with filter type B 7th order
Bandwidth = 97.8%
Phase minimum phase
AUTO: /Users/…
Library database path: /Users/…Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50040
Integer mode: ON
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Hog Mode is on
ID 0x3c
DSD via PCM 1.1
36 virtual formats:
54 physical formats
Reduce your playback pre-load memory allocation to 4GB you are allocating 13GB of your 16GB System Memory for playback buffering…
Shut down Audirvana, shut-down your computer and DAC… restart your computer, then the DAC, wait for them to connect and stabilize… Make sure your TEAC is selected as the audio output device in Audio MIDI Setup… and launch Audirvana…
No reason to limit the bit-depth to 24bits… and don’t run a virtual machine… No drivers needed on macOS… Turn-off ā€˜Polarity Inversion’
Okay this is your problem with DSD256 via DoP 1.1… The UD-503 USB input supports up to 384kHz or in the context of DoP transmission up to 352.8kHz which is the PCM carrier sample-rate for DSD128 (5.6MHz)… You cannot play DSD256 via USB (native or DoP) from a macOS platform… However, you can play native 1-bit PDM DSD256 via Ethernet UPnP transmission… The TEAC HR player is bound by the same USB restrictions… apparently you were using a Windows virtual machine when playing the DSD256 file.
Note: To play 11.2MHz DSD256 files via DoP 1.1 on the USB bus, the UD-503 would need to support the PCM carrier sample-rate of 705.6kHz.
*** It can internally up-sample to 11.2MHz…*
Thank you. OK, the data overhead that DOP need (well explain in your link on the DOP 1.1 spec signed by D.Plisson) to build the container make that you always are a step under transport rate.
That’s why when I play, with my mac and TEAC HR a 256 DSF file, it proof that TEAC HR isn’t using DOP.
So in the task manager I’ve made a sample of the code used by TEAC HR on the mac and they use ā€œITFAudioToolkitā€, a free code made to manipulate DSD bypassing CoreAudio Apple code. here is an extract, I can send the all file to your R&D of course :slight_smile:
! 1 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) (in CoreAudio) + 247 [0x7fff33135c79]
14 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) (in CoreAudio) + 5639 [0x7fff3303291a]
! 4 io_proc (in ITFAudioToolkit) + 127 [0x10b7edd58]
! : 4 -[AudioOutputContext deviceInfo] (in ITFAudioToolkit) + 34 [0x10b7d3903]
! : 3 objc_copyStruct (in libobjc.A.dylib) + 96 [0x7fff6c5fcc0a]
! : | 3 mutex_tt::lockTwo(mutex_tt, mutex_tt) (in libobjc.A.dylib) + 28
What is ITF audio Toolkit ?
ITFAudioToolkit
An update that allow all mac user to use the full capacity of their DAC coud be a a tremendous commercial advantage ! https://itf.co.jp/prod/audio_solution/itf_audio_toolkit
Too bad Damien Plisson doesn’t make keynotes, A revolution like that deserve one !:grinning:
I play both native and DoP 1.1 DSD files to 5.6MHz via USB to my TEAC UD-501… I modulate (up-sample) all PCM files to DSD128 (5.6MHz) in r8Brain. I convert binaural DSD256 to DSD128… Since I am headphone-centric, I convert stereo DSD to DXD (24/352.8kHz) where I apply HRTF DSP (112dB Redline Monitor) and subsequently modulate to 5.6MHz…
The idea that packetizing DoP signals influence the 1-bit PDM signal embedded in the PCM carrier is misinformed… Both r8Brain or Sox packetize the DoP framework and the DoP de-embedding processor of the DAC do this adroitly and delivers the 1-bit PDM stream intact to the output circuitry…
This requires that you install the ITF-USB DSD protocol driver as this is a proprietary handshake between the USB bus controller and the UD-503 with the symbiotic ITF-USB DSD protocol hardware/firmware support.
You are worried about CPU overhead… This does not reduce overhead…
You can utilize a streamer/DDC to provide the native DSD256 via USB to the UD-503…
My perspective on DSD256 is that you will be hard pressed, at best, to discern tangible contextual nuances between a recording done at 5.6MHz versus a recording done at 11.2MHz on your system… Even if you decimate the 11.2MHz file to 5.6MHz for playback via DoP 1.1.
Note: My Apple Inc, platform for Audirvāna 2.9.4.1 is a M2 Max Mac Studio with 64GB RAM, macOS Sequoia 15.1.1
I do exactly the same thing and appreciate the very good result, that’s why I want to try 256. TEAC HR doesn’t upsample.
I Agree.
Is it possible with Audirvana ?
any model suggestion ?
If you like TEAC product the same company make also the bulk PET 独自USBä¼é€ęŠ€č”“ Bulk Pet(ćƒćƒ«ć‚Æ ペット) | ć‚¤ćƒ³ć‚æćƒ¼ćƒ•ć‚§ć‚¤ć‚¹ę Ŗå¼ä¼šē¤¾
this product doesn’t seems to exist in stand alone, it must be integrated in the software, so why not in Audirvana ? :slight_smile:
If you want to play DSD256 files just use the TEAC HR player…
There is no benefit for Audirvāna to pay for a software driver to support some older DAC’s that don’t support 11.2MHz DoP files via USB…
  • Bulk PET protocol requires the symbiotic DAC platform support.
** Suggestion: Down-convert your DSD256 files to DSD128… your enjoyment of the artistry and production will not be diminished, except for the cognitive-bias you may hold and you then can seamlessly jump between format/sample-rates.
I want to oversample Qobuz PCM to 256
I’m waiting for the 507 :grin:
It’s available… :sunglasses: :+1: It may be questionable to utilize r8Brain when you can employ the UD-507 platform modulation engine… This will require some comparison.
