So as @Antoine just posted it’s strictly a windows only issue so my Mac results are not helpful for you really, did you install the test version Antoine suggested?
I see you have installed it I believe, it’s still 1.12.2 I’m just guessing as I’m not going to tempt fate as my Mac is working pretty good currently.
We need a couple of windows users to test this further for you and Antoine
I’m not sure if it’s really a setting that can be changed.
Speaking of settings, if you have this test version and you are connected to a Tidal account, there is something you should check in the Tidal settings of Audirvāna Studio
the assumption because of the setting was the release note windows 1.12.2: “Internet Radios: Improve buffering to remove any unwanted short pause during playback” So I thought the buffer size was adjusted. What also explained the current behavior to me. What was that the buffer was full after 7 minutes.
But it’s your turn and you’re on the right track to correcting the error, waiting for new test if you need more.
And I’ll probably watch Tidal too! Thank you so far.
MacJK
P.S.I just realize my name, not match my Hardware, I fix this this next year at an Apple Store.
What I’m talking about is different that what you see in the release note. I need to do a 1 hour listening to radio to see if I can reproduce your issue with the test version.
I’ve been playing Radio paradise with the test version of Audirvāna Studio on my Windows 10 computer for almost 2 hours and no issue so far. I will come back to you next week about it to see what we can do with Damien.
When you get this notification, can you go in task manager, click on the arrow next to Audirvāna Studio and then right click on Audirvāna Studio under it and select" create a dump file"?
I had problems with radio playback (Windows) with slutterings and stops since the beginning of AS. From February (I guess) the playback has been improved and from a month I have few slutterings on playback sometimes and than works perfect. In the past when playing radios and made other things, for example even opening a browser, more slutterings occured. Now (from a month or something) is stable like a rock. I changed my mind and will renew my annual sub for AS in August. The sound is incredible, the software is now stable, at least for me, certainly you are on a good direction!
