Thumbnails not updated
I have found some new and better album cover images. I copied them to the album directories and replaced the existing Folder.jpg file.
It seems that Audirvana does not update the thumbnail images. Is it possible to update all thumbnails or a selection?
Hi @Benno,
Have you tried to restart Audirvāna?
Hi @Antoine,
Yes, I have restarted the app using “close all apps”.
Audirvana displays the right image only in full album-image view.
The album list view and the album tracklist view display the wrong image.
Kind regards,
Benno Jansen
Which version of Audirvāna are you using? Is this the Linux/Windows/MacOS version?
Audirvāna on QNAP NAS, app on a Samsung Tab A8.
I will check this out and report you back as soon as possible.
I have reproduced the issue. To make sure we are on the same page, your tracks do not have cover embedded in them, however you put a cover.jpg file in the album folder which is then displayed in Audirvāna.
You then wanted to change this file with a different one, but it is never updated in Audirvāna. Can you confirm this?
That’s correct.
Only one small remark, just to be precise; the filename of the album image is called ‘Folder.jpg’ and it’s the only image in the directory.
Hi guys, can you please try to reproduce the issue with this test version?
https://audirvana-my.sharepoint.com/:f:/p/antoine/EjMdZM34U_pDmKaikyNCH4oBToQ9YXEn_8dSFa6Jt4wMmw
Hi @Antoine,
I will test the beta next week. Currently I’m on holiday in Rouen-Vouvray-Caen. :slight_smile:
Regards
Benno.
Hi @Antoine,
I’m afraid that the issue is not yet resolved :disappointed_relieved:
It seems that the album image is only updated if one of the album’s music files is renamed.
In the search result I first saw ‘Offspring’ and ‘The Offspring’, but after changing a track file name, the album image was updated and the correct album artist was listed in the search results. The file path remained unchanged.
Almost immediate update: Change of track title and/or track artist
After filename update: Change of Album artist and/or image (Folder.jpg)
