Tidal Autoplay is selected in Streaming Preferences but doesn’t kick in after an album from my local library played it’s last song. The function did work on Roon but after I switched to Audirvana I was not able to get it working.
I’m running Audirvana Studio v 2.2.5 on macOS 12.6.3. Monterey
Thanks for the feedback,
I did upgrade to 2.2.7 , unfortunately to no avail. I don’t use shuffle when playing my own albums. Autoplay doesn’t work no matter which album I play.
That’s strange tho, you may have already done this but, have you disconnected and reconnected your Tidal account from Audirvāna Studio?
Yes I did, also after the upgrade. Should a reinstall be considered, I just wanted to make sure that it all works before my trial periods are over.
You can reinstall it but it if it still doesn’t work, we will need to dig a little bit more so I can try to reproduce your issue.
Reinstall did not do it unfortunately
Is this what you’re looking for?
It’s correct that Autoplay doesn’t work if playing a song on an album with multiple tracks.
Unlike single track albums, Autoplay works normally.
This is from a local track, can you do the same from the same track I played from Tidal?
By default I play the whole album, not just a track…then I expect after playing the whole album that Tidal kicks in and continues with similar genre music.
Yes, from the album in Tidal, not Local.
I got you!! So autoplay doesn’t work after playing one’s own album. So I misunderstood it’s function in Audirvana.
It does but in your case there is more involved here. It seems your tracks have not been analyzed by the software.
Hope this helps:
Audirvana Studio 2.2.7 (20208)
macOS 12.6.3 with 8GB physical RAM
Connected account of :
Manual: /Volumes/music/
Library database path: /Users/egravenb02/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50169
TIDAL: Connected as PREMIUM
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
AudioQuest AudioQuest DragonFly Black v1.5
Model UID:AudioQuest DragonFly Black v1.5:21B4:0083
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Black v1.5:AQDFBL0100030096:1
Active Sample Rate: 96kHz
Selected device:Built-in Output
Model UID: AppleHDA:126
ID 0x31
Stream ID 0x32 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x31 Built-in Output
Chromecast devices found : 1
Device #0: Shed TV
Model name: Chromecast
Can you please remove this folder to be synced and add it again? After adding it, can you check if you have tracks with no Musicbrainz ID in the Metadata recovery section?
Work in Progress
Removed and reinitialised the music folder.
Over 8000 tracks with no MusicBrainz ID after 99% audio files analysed.
Result, Autoplay doesn’t work with local albums… only Tidal albums.
