Hello,
I am having major buffering issues to the point that Tidal is unusable with audirvana.
The song pauses from buffering after the 20% of buffering and then its either pause and play and pause or sometimes suddenly white noise starts playing.
Pasted below is the debug info. Thanks.
Audirvana Mac Version 3.5.33 (3563)
macOS 10.11.6 with 4096MB RAM
Registered to Bhaskar Rao
UPnP devices found : 1
Device #0: ID 0x0 TDAI-3400 UID: uuid:c0200bd8-4bde-49dc-aa7b-9c1d0448abbb
Direct Mode audio path, buffer I/O frame size: 0
Max. memory for audio buffers: 3072MB
Device #0: ID 0x35 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
