I have a song on Tidal is 24/96 MAQ but playing as 24/48 PCM on my Topping D90SE DAC.
Here the debug info:
Audirvana Studio 1.8.5 (10805)
macOS 12.0.1 with 8GB physical RAM
Globally: ON
No plugin active
SW volume control: ON
AUTO: /Users/kevin/Downloads
Library database path: /Users/kevin/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 60622
CoreAudio audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 5188MB
Exclusive access: Disabled
TOPPING D90SE
Model UID:D90SE:152A:8750
UID:AppleUSBAudioEngine:Topping:D90SE:1110000:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
ID 0x38 D90SE
Manufacturer: Topping
Model Name: Topping D90SE
Model UID: D90SE:152A:8750
UID: AppleUSBAudioEngine:Topping:D90SE:1110000:1
MQA Decoder device
Stream ID 0x39 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x38 D90SE Manufacturer: Topping Model UID: D90SE:152A:8750 UID: AppleUSBAudioEngine:Topping:D90SE:1110000:1 Model Name: Topping D90SE
Device #1: ID 0x2c MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
