TIDAL Search Not Working in Audirvana – No Results
Hi everyone,
I’m currently using Audirvana connected to TIDAL, and I’ve encountered a really frustrating issue. When I try to search for any song within Audirvana, nothing shows up — it’s just blank, no results at all.
Both my TIDAL and Audirvana apps are fully updated. I’ve already tried the following steps:
  • Restarted my router
  • Reinstalled the TIDAL app
  • Disconnected and reconnected my TIDAL account in Audirvana
Unfortunately, none of these actions solved the problem. Has anyone else experienced this? Any ideas on what might be causing it or how to fix it?
Thanks in advance!
You probably inadvertently have filtered out Tidal from the search results. In the left hand column you can see if there’s a strikethrough in the looking glass symbol next to the name ‘Tidal’.
Yes, it works now. Thank you!
