Hi
Connected to TIDAL and album view show up but when trying to play it says “Loading first track” and then “unable to play an audio file”
I can play from my local files though.
Any ideas on why this is?
Magnus
If this is on Windows 10, there’s a known issue with Tidal signing into Edge, which has obviously not been sorted with Tidal, so you’ll have to quit Audirvana and connect again with Tidal…
Still have to quit, restart and reconnect to Tidal about once a day…
After the latest update, still being forced to quit, restart and reconnect to Tidal: do I need to reinstall the software or is anyone else having the problem?
Hi, i just purchased Audirvana few days ago, i still havent been able to play anything from TIDAL. Whenever i try to play any song from TIDAL in Audirvana it just says “Unable to open an audio file for playback”. TIDAL itself work just fine.
Iam out of options on what to try, hopefully someone here can help.
Windows 10 - latest version
I tried both but no change. I also want to use primarily Audirvana with Rpi/Volumio, so this shoudnt be an issue anyway. But i tried it with DAC connected directly to PC but nothing helped.
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content, all you have to do is paste it in response to this email
Hello, looks like i made it work. For some reason audirvana signed my Tidal acc as “FREE” after logging in several times it now shows correctly “Hifi”
Thank you for help
Hi , i am having this issue with Mac OS Big Sur , I wish you can help me.
Hello @Carlos_Lopez,
