Tiny Bug in Technical Miniplayer
If you hover over the software volume control, the tooltip says that software volume control is disabled even though it is enabled.
Please paste your debug information here…
It is found here: "Settings–> My Account–> Help–> Debug Info
To have that option working at a party your files have to be analyzed first…
i say party but meaning a playlist with different songs from different albums… if you don’t want to higher or lower volume all night :slight_smile:
Hi @TribecaMikey,
Can you send us a copy of the "Debug Info“ when you have this behavior? You can get it in Audirvana Settings>My account.
Audirvana Origin 2.5.14 (20514)
macOS Version 14.7 (Build 23H124) with 16GB physical RAM
Connected account of : Michael Sacks
	AU plugin #0: Music Effect - MeldaProduction MEqualizer ()
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
Replay Gain: by album
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/OWC HD/iTunes/iTunes Media/Apple Music
AUTO: /Volumes/OWC HD/iTunes/iTunes Media/Music
Library database path: /Users/msacks3/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 54533
Font size: large
Library
My Music
Startup view: Last displayed view
Use Apple Remote: no
Number of paired remotes: 4
Screen saver disabled: no
Max. memory for audio buffers: 4356MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Schiit Audio Schiit Unison Modius ES
Model UID:Schiit Unison Modius ES:30BE:101A
UID:AppleUSBAudioEngine:Schiit Audio:Schiit Unison Modius ES:2400000:1
Selected device:External Headphones
Model name: Apple Inc. External Headphones
Model UID: Codec Output
UID: BuiltInHeadphoneOutputDevice
ID 0x50
Stream ID 0x51 2 channels starting at 1
4 virtual formats:
4 physical formats
Local devices found : 4
Device #0: ID 0x64 LG HDR 4K
Manufacturer: GSM
Model UID: 1E6D0777-0000-0000-051D-0104B53C2278
Model name: GSM LG HDR 4K
Device #1: ID 0x73 USB Audio CODEC
Manufacturer: Burr-Brown from TI
Model UID: USB Audio CODEC :08BB:2906
UID: AppleUSBAudioEngine:Burr-Brown from TI :USB Audio CODEC :2400000:1
USB Vendor ID: 0x08bb
USB Product ID: 0x2906
Model name: Burr-Brown from TI USB Audio CODEC
Device #2: ID 0x50 External Headphones
Device #3: ID 0x4a Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
@RunHomeSlow, thanks for your response. I want to make sure I understand your recommendation.
  • Turn Volume Leveling off - only use it if you have a playlist with songs from lots of different albums
  • Is it stilll OK to use Software Volume Control?
  • One implication of this is that the ReplayGain info that Origin has calculated for each album is informational only - Origin will not use it in playback
  • Your reasoning is that Volume Leveling causes Origin to modify the signal during playback.
  • Doesn’t Software Volume Control also affect the signal?
    Thanks.
If your DAC as a volume control, better to use it instead of software volume control… If your DAC doesn’t have one, you have to use it… Audirvana is suppose to have a good software volume control… i don’t know, my DAC as a control.
Sure using levelling option affect the file… affect the sound, good or bad ? you have to decide if it does… I’m usually an album listerner instead of random songs. The option that keep levelling for album in the prefs is mostly for people that don’t want to change that option when playing playlists for exemple then decide to listen to an album… Does Audirvana do something when album preserving gain is on and you listening to an album between random songs??
better off for me always, then, if i listen to a playlist with all mixed up songs… that option is helpful because it is annoying to listen to a classic song, followed by a rock song, to a jazz song after, with all different replaygain number… you have to lower the sound, then you have to put it up for classic, then lower it for a bad new mastering with low DR… With the replaygain option on, it levels all the listening of the playlist to a regular sound, good or bad, you have to decide.
these days i have a smart playlist that was made with never played songs in my database… the option in that playlist is by time of songs… so the songs are all from different groups and albums all mixed up… i use the replaygain option when playing that playlist, apart from that, i don’t use replaygain option, nor use software volume control. But for some, Software volume control is not an option they have to use it :slight_smile:
if the option in pref is off, it is information only. You don’t have to calculate replaygain info for your tracks, that is off by default. But you have to calculate your songs if you want to use that option after… My database is all calculate.
When using software volume control, the dynamic range (bit-depth) of the file is changed… the LPCM format reference being: (6dB = 1-bit). If the software volume calculations are done at 32bit (Theoretical 192dB dynamic range) you can see that even a level adjustment of -12dB results in a 2-bit reduction in dynamic range when converted to the bit-depth of your 24bit DAC which would be 22bits (Theoretical 132dB dynamic range)… Your DAC most likely does not reproduce this level of dynamic range… A 16bit file (CD, etc) has a theoretical dynamic range of 96dB… Most likely, your playback system cannot reproduce the dynamic range reproduced from the 24bit files.
Will you please paste the debug information from when you are using the Modius DAC… The report you pasted here is when you have headphones connected to the Mac… We know this because the supported maximum sample rate is 96kHz.
Oops. Here you go. I am experimenting with Volume Leveling on/off and Software Volume Control on/off to see if I can hear the difference.
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
Listening on 127.0.0.1 on port 55327
Font size: large
Library
My Music
Integer mode: ON
Use max I/O buffer size: OFF
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Hog Mode is on
Limit bitdepth to 24bit: ON
Selected device:Schiit Unison Modius ES
Manufacturer: Schiit Audio
Model name: Schiit Audio Schiit Unison Modius ES
Model UID: Schiit Unison Modius ES:30BE:101A
UID: AppleUSBAudioEngine:Schiit Audio:Schiit Unison Modius ES:2400000:1
USB Vendor ID: 0x30be
USB Product ID: 0x101a
ID 0x73
Max volume alert: Disabled
Stream ID 0x74 2 channels starting at 1
24 virtual formats:
36 physical formats
Manufacturer: GSM
Device #1: ID 0x73 Schiit Unison Modius ES
Model UID: Speaker
Got it. Although my DAC doesn’t offer volume control it’s connected to a tube amplifier that offers volume control via a remote control handset. So strictly speaking I don’t need software volume control. I am currently experimenting with Volume Leveling on/off and Software Volume Control on/off to see if I can hear a difference.
You are best served by disabling software Volume Control when you have an amplifier with volume control…
I suggest using “Power of Two” upsampling as this will calculate the proper logical result from the fundamental sample-rate…
*Example:
  • 44.1kHz–> 176.4kHz
  • 48kHz–> 192kHz
  • 88.2kHz-> 176.4kHz
  • 96kHz–> 192kHz
Apparently the specification information on the Schiit site about Modius is incorrectly describing the DAC max bit-depth as 24bit, when it is capable to 32bit.
Thanks for the suggestion. I have implemented it and am listening right now.
Here’s an email exchange I had with Schiit technical support. It may be of interest:
Dec 26, 2022, 10:46 PST
Hi. Happy Holidays. I have a Modius with which I am extremely happy. I feed it with Audirvana Origin. I can send it Sample Rates and Bit Depths of 24/192 or 32/192. Which do you recommend?
Thanks.
Dec 27, 2022, 08:45 PST
Hello,
24/192 since that is the max sample rate the Modius can playback. It can playback when set to 32/192, however it will still only convert to a max of 24/192.
All the Best,
Tom E.
Thanks.
The ESS ES9028 chipset (variant ???), used in the Modius “E” is a 32bit DAC (it seems all 9028 variants are 32bit) and we see this reflected in the debug report regarding playback format support. However, the D/A circuit (Digital to Analog) output signal from the chipset is referenced to a real-world dynamic range of approximately 24bits. (Theoretical 144dB dynamic range… You will see the real-world output specs in the review below…)
Here is a review and measured performance results… These measurements don’t tell you how the DAC sounds… they are comparative in nature… and should be viewed as reference points…
I have had software volume control turned off since October. I use Volume Leveling from time to time when I’m listening to playlists and turn it off otherwise. Today I was listening to an album but forgot to turn off Volume Leveling. The album had been ripped from a commercial CD. On a certain track it produced significant distortion - as if there had been audio clips during the recording of the track. When I turned off Volume Leveling the distortion went away. @Agoldnear, is this of any interest to you? If it is I will send my debug info and an aiff version of the track. If you’re not interested I will forget about it.
Only this CD rip?
If it is from the 80’s this could be Inter-Sample Peaks (ISP’s) due to normalization of the file(s) in the mastering of the disc (Loudness Wars)…
Or pre-emphasis:
In processing electronic audio signals, pre-emphasis refers to a system process designed to increase (within a frequency band) the magnitude of some (usually higher) frequencies with respect to the magnitude of other (usually lower) frequencies in order to improve the overall signal-to-noise ratio by minimizing the adverse effects of such phenomena as attenuation distortion or saturation of recording media in subsequent parts of the system. The mirror operation is called de-emphasis, and the system as a whole is called emphasis.
Emphasis (telecommunications) - Wikipedia
Are you up-sampling PCM?
How are you controlling your playback gain/volume otherwise?
Thanks for your response.
Only this CD rip?
So far it’s the only one I’ve noticed.
Here’s the CD:
r8brain with Power Of Two upsampling
My DAC has a wired connection to my tube amplifier. I use the volume control on my amp.
Is the output impedance of the DAC matched to the input of the amp?
When up-sampling, you are adding gain via dynamic-range expansion, so you are going from 16bits to 24bits (96dB theoretically and 144dB theoretical) real-world somewhere around 120-130dB or less…You may need to lower the output volume of Audirvāna a little bit in-order to manage the gain structure to avoid clipping distortion, if this is in fact the precipitator of this noise… However, you cannot eliminate ISP’s and emphasis in this case…
[Note: 1bit = 6dB]
Looked up the specs of my dac and amp but output impedance on the dac and input impedance on the amp are quoted in ohms not in db. Not sure how to proceed.
Most likely when you lower the volume in Audirvāna, distortion will be eliminated if it is due to the increase in dynamic-range, otherwise you may be hearing some distortion that made its way onto the master…
Ohms represent the signal impedance… not dB… Decibels (dB) refer to the dynamic-range/amplitude/loudness of the signal…
When you reduce the gain/amplitude of the signal with the Audirvāna digital volume control by -6dB you will have reduced the dynamic-range of the signal by 1-bit… so if you reduce the output gain by -3dB you will have lost .5dB of dynamic-range and in the case of a 24-bit signal which has a theoretical dynamic-range of 144dB you have reduced this to 143.5dB… The CD rip had a theoretical dynamic-range of 96dB before up-sampling, so you can see where the signal could be clipping the input of your DAC or the output of the DAC is clipping the input of your amp… You won’t be losing anything by slightly lowering the volume in Audirvāna. :wink:
EDIT:
You may find other discs that reveal this distortion when volume leveling is disabled… I would try to find those recordings and use them as a reference level to adjust the volume output so to prevent this overload clipping distortion when playing files that have been normalized for loudness, if in fact this is clipping distortion… It should not be more than -1dB or -2dB or -3dB in reduction… This could be inherent in the DAC input architecture and backing-off the volume in Audirvāna should prevent this clipping distortion, and when you enable volume leveling again, you will need to balance the gain structure to suit…
