Hello, I have run into the dreaded “too many installations” error when I try to activate Audirvana.
My email is [email protected]
Thanks for your help!
Randall Jonasz
Randall Jonasz
Hello @rjonasz,
I have removed all your computers from the license database. You can now activate up to two PC running Windows 10.
To install Audirvana on your PC, you can proceed as follows:
Hi Damien3
I had to reinstall Windows 10 after a crash and I getting the “too many installations” trying to activate Audirvana.
Thnx,
Edwin Hernandez
Hello @hernae1969,
Hello @Damien3
After reinstalling Windows 10, when I enter my license key into Audirvana, I get “Too many installs”.
The order number is #93410636.
Thank you.
Salut @Damien3, I just bought the cross platform upgrade and Audirvana on Windows 10 complains about too many activations, my macOS installation has been deleted recently (I didn’t know I had to deactivate Audirvana). Order number is #13850347. Merci.
Can you please remove my prior licenses from the database so I can install on a new Windows 10 install?
Thanks!
Hello @fiwa, @clar2391 and @ralfom, It’s done for you too, I have removed all your computers from the license database.
hello @Damien3. I’ve got the same problem, but only installed on 1. I need to install on 2 windows machines. Thanks.
My order was 87650817
Hello @mapufre,
You can now activate up to two computers.
To install Audirvana on your computer, you can proceed as follows:
@Damien3
Você pode remover minhas licenças anteriores do banco de dados para que eu possa instalar em uma nova instalação do Windows 10?
Obrigado!
You have received it by mail when you made the purchase of Audirvana.
Mandei uma msg no seu pv dá uma olhada por gentileza
Hello. I bought a new computer and it’s blocked. Can you please unlock the account? Thank you in advance. Panagiotis.
Hello @koupa,
