Hello Damien,
I have a same Problem. Can you remove my Installation on my another PC-s
thank you
Hello Damien,
thank you
Hello @wbalu8,
I have removed all your computers from the license database.
You can now activate up to two computers.
To install Audirvana on your computer, you can proceed as follows:
Hello, I have run into the dreaded “too many installations” error when I try to activate Audirvana.
Thanks for your help!
I have a combined Mac/windows10 license, and also get the “too many installations” error. Could you please reset my license as well. Thank you so much.
Hallo Damien3,
leider habe ich auch zu viele Installationen für meinen Schlüssel. Habe zwar nur zwei Installationen, aber bei der Deinstallation nicht bemerkt, dass ich vorher im Programm die Aktivierung löschen muss. Bitte um Hilfe
Viele Grüße
Gerd
Per favore ho fatto reset del PC e non riesco ad attivare la mia licenza, potete cancellare tutti i miei pc cosi posso attivarla, Grazie, Adriqno
Hello @Adriano_Cavallo,
Bonjour, j’ai 2 licences Audirvana une windows et une mac, un de mes ordinateurs Windows a planté et en voulant réinstallé ca m’affiche ce message, si vous pouvez m’aider à régler le problème s’il vous plait, Numéro de commande 112195813 merci
I have reinstalled my OS and received the “too many installations” error. Could you assist to reset my license please. Thank you.
order number is #22484348
Hello @ysl,
Order no. #13512315
Please remove all my computers from the licence database.
Thank you.
Hello @bnd11 ,
Hey,
i tried to install audirvana on my device and it says too many devices. Can you please remove the existing computers so i can add my new one?
Best regards
Deepak
Damien3,
Please reset license. Thank you.
What a load of crap. Begging to use a poorly written piece of code. So I paid over $100.00 for this junk. I’d rather kiss the money good bye.
Dear Damien3, I bought Audirvana couple of months ago, I’m using it on two computers. One of my computers crashed before I deactivated Audirvana. Now I can only use it on my Notebook, I can’t install it on my desktop computer because of too many activations.
How can that be solved?
Thanks in advance,
order number 17349523, please help me to reset my windows license
Hi, I have to reinstall windows in one pc and can’t reinstall audirvana.
