Too many installations for Windows 10
Hello @Juan_Zumaeta_Bossio, @aquariusjr10 and @Saintfra,
I have removed all your computers from the license database.
You can now activate up to two computers.
To install Audirvana on your computer, you can proceed as follows:
  1. install 3.5 version : https://audirvana.com/try/
  2. unlock it by loading your license key
Hello @Junique and @drwilley,
Can you send me in a private message the mail you used or your license key so i can find you in our database?
When installing license on the formatted PC it indicates that there are many PCs with active licenses, please remove active licenses to enable Windows 10.
Thanks for your help
Roberto Perez.
Hello @robertostgo,
Thank you so much!! have a great day
hi @Damien3 @Damien @Damien2 i am trying to add the license in audirvana 3.5.46 on mac mini and i get a message that no license is available. i had this license installed on a macbook Pro and i have revoked it before installing on mac mini. Could you please check what happened to my license?
Hi Damien!
Please remove my installations from the database. Order 22213662,
Thanks and best regards, Peter
Bonjour Damien
Je n’ai pas pu desinstaller la version 3.5 de mon ordinateur suite à un plantage total
Pouvez vous remettre à zéro la database des licenses
merci d’avance
jlpweb17
