Please help…
I no longer have my MacBook Air and now also have the “too many licenses problem” on my new computer.
My Order number is 91288365 2019-02-21
Thx!
Thilo
Please help…
Thx!
Thilo
Hello @tomnab,
I have removed all your computers from the license database.
You can now activate up to two computers.
To install Audirvana on your computer, you can proceed as follows:
The activated iMac has failed and can no longer be used.
Please remove it from the license database to activate it on your new Macbook.
(Order: 60601409)
Hello @vacboss,
Hi Damien, unfortunately I have the same problem, after I reinstalled my Mac mini with Windows 10 and didn’t removed my license before. My order no is: #24261279.
Thanks in advance and all the best
Peter
@ckfoisie I wouldn’t post you license number on a public forum (or any forum for that matter) if I were you. Now anyone can use it…
Hello Damien3,
please remove all my computers from the license database.
Thanks and stay healthy!
Regards, Eckart
Hello! My old Mac Pro failed with an active Audirvana license. Order number was 56382120. Please unlock the second computer so I can reinstall. Thanks.
Hello @peter.fuhrhans, @rohdecan and @ckfoisie,
If you post the license key then yes, anyone can use it but the order reference is only useful for us as it is linked to your purchase of Audirvana. You don’t unlock Audirvana with it, only the license key can.
Ho un problema di licenze. Avevo un vecchio mac mini in cui si è rotto l’Hard disc. Non ho potuto disinstallare audirvana Cosa posso fare Grazie
Hello @Enrico_Vivalda,
Hi Damien3, Please remove all my computers from the license database.
My order numbers are:
Windows version #97024770
Mac version #59728899
Have a nice day!
Hello @Casval,
Hi Damien3.
I also initialized my Macbook before removing the Audirvana license!
Please remove my computers from the license database.
Order number: #15407672
Hello @11157 ,
Thank you for your prompt reply!
Hello Damien3,
Windows version # 113802320
Mac version # 60998510
Thanks in advance!
Hello @tifusa ,
