Bonjour
Les fichiers DSD 5.1 ne sortent pas en surround mais en stéréo alors que les fichiers FLAC 5.1 sont lus en surround. Voila ma config.
Merci
Audirvana Origin 2.2.2 (20202)
Windows 11 (22621) with 24GB physical RAM
Connected account of : Jean-Claude
Per track: OFF
AUTO: E:\HD
Library database path: C:\Users\jcpei\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:e0a:538:26c0:5ba:ce65:c556:ee09 on port 57065
Max. memory for audio buffers: 9774MB
Local Audio Engine: ASIO 2
Driver version 1330
Topping USB Audio Device
Model UID:Topping USB Audio Device
Active Sample Rate: 2822.4kHz
Selected device:Topping USB Audio Device
Manufacturer:
Model name: Topping USB Audio Device
Model UID: Topping USB Audio Device
8 available sample rates up to 5644800Hz
5644800
DSD capability: Raw DSD (MSB)
Multichannel: 8 channels
Channel bitmap: Ox63f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
8 ch Integer PCM 32bit little endian 44.1kHz
8 ch Integer PCM 32bit little endian 48kHz
8 ch Integer PCM 32bit little endian 88.2kHz
8 ch Integer PCM 32bit little endian 96kHz
8 ch Integer PCM 32bit little endian 176.4kHz
8 ch Integer PCM 32bit little endian 192kHz
8 ch DSD 8bit big endian in 8bit chunk 2822.4kHz
8 ch DSD 8bit big endian in 8bit chunk 5644.8kHz
Local devices found : 8
Device #0: AudioBox ASIO Driver
Manufacturer:
Model UID: AudioBox ASIO Driver
Model name: AudioBox ASIO Driver
Device #1: DSD Transcoder (DoP/Native)
Manufacturer:
Model UID: DSD Transcoder (DoP/Native)
Model name: DSD Transcoder (DoP/Native)
Device #2: foo_dsd_asio
Manufacturer:
Model UID: foo_dsd_asio
UID: foo_dsd_asio
Model name: foo_dsd_asio
Device #3: Studio 192 ASIO
Manufacturer:
Model UID: Studio 192 ASIO
Model name: Studio 192 ASIO
Device #4: Studio USB ASIO Driver
Manufacturer:
Model UID: Studio USB ASIO Driver
Model name: Studio USB ASIO Driver
Device #5: StudioLive Series III ASIO
Manufacturer:
Model UID: StudioLive Series III ASIO
Model name: StudioLive Series III ASIO
Device #6: Topping USB Audio Device
Manufacturer:
Device #7: USB DAC ASIO
Manufacturer:
Model UID: USB DAC ASIO
UID: USB DAC ASIO
Model name: USB DAC ASIO
