Track rating via mousing over impossible if track has no rating already
Hello, I just added the rating column (classement) in my display but if no track rating is set already I cannot use it (no stars displayed while mousing over) unless going through the metadata panel. If I add one or more star from the metadata panel then the rating is diplayed in the column and I can change it. But if I change it back to 0 star then I have no possibility to rate it again with my mouse as all the “empty” stars are gone. So I must go back to the metadata panel etc. I hope this is clear.
Does it look like a bug ? I’m using v2.11.0 on Win11
Look like a bug for the Windows version.
look alright on Origin Mac.
Hi @Eric50,
It was missing in the Windows version; we will fix it in a future update of Audirvāna Studio/Origin.
