I’m playing Tidal to an UPnP streamer and I cannot seek to play from an earlier time in a track that is playing. When I click on an earlier position of a track, it briefly pauses and just continues playback. I’m confused why that is?
Hi @trick3,
Hi @Antoine, pasting the debuginfo below.
Audirvana Studio 2.11.0 (21100)
Windows 11 (26100) x86_64 with 32GB physical RAM
Connected account of : Jozo Slejko
Available network interfaces:
Ethernet ({bbe6583d-367b-4aff-bf52-f84421bdffc1}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
DSP NOT ACTIVE
Sync list: 2 folders
AUTO: D:\Music
AUTO: D:\Setup
Sync folders at startup: YES
Sort and display order: en_US
Library database path: C:\Users\jozoslejko\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 380
Listening on fd7a:d1d1:7197:e84d:4f3:578d:47c8:11bf on port 58692
TIDAL: Connected as PREMIUM
Font size: large
My Music
Streaming
Radios
Podcasts
Startup view: My Playlists
Number of paired remotes: 3
Screen saver disabled: yes
Active method: UPnP
Ethernet
Preferred device: [UPnP] Linn Selekt:UPnP AV Model UID:Linn Products Ltd Selekt DSM Edition UID:uuid:4c494e4e-0026-0f22-7cc1-016177450171
Selected device:Linn Selekt:UPnP AV
Manufacturer: Linn Products Ltd
Model name: Selekt DSM Edition
Model UID: Linn Products Ltd Selekt DSM Edition
UID: uuid:4c494e4e-0026-0f22-7cc1-016177450171
UPnP device at http://192.168.88.128:55178/4c494e4e-0026-0f22-7cc1-016177450171/Upnp/device.xml
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get::audio/mp4:
http-get::application/vnd.apple.mpegurl:
http-get::audio/aac:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/aifc:
http-get::audio/x-aifc:
http-get::audio/x-m4a:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::application/ogg:
http-get::audio/wav:
http-get::audio/wave:
http-get::audio/x-wav:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/x-ms-wma:
http-get::audio/x-ms-asf:
http-get::audio/x-ms-wax:
http-get::audio/x-ms-wvx:
http-get::video/x-ms-asf:
http-get::video/x-ms-wax:
http-get::video/x-ms-wvx:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/mp1:
http-get::audio/x-mpegurl:
http-get::audio/mpegurl:
http-get::audio/x-scpls:
http-get::text/xml:
tidalhifi.com:::*
qobuz.com:::*
DLNA 1.5: No
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB (-80dB to 20dB)
NrTracks: 1
MediaDuration: 2:15:15
CurrentURI: http://192.168.88.159:49152/audirvana/audio_r_30.wav
CurrentURIMetadata:
dc:titlemp3, 44100 Hz, stereo, 320 kb/s</dc:title>
upnp:albumArtURIhttp://static.airable.io/85/90/915765.png</upnp:albumArtURI>
upnp:albumRadio Paradise Main Mix</upnp:album>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
Current transport actions:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Linn Selekt:UPnP AV Linn Products Ltd Selekt DSM Edition uuid:4c494e4e-0026-0f22-7cc1-016177450171 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /4c494e4e-0026-0f22-7cc1-016177450171/Upnp/upnp.org-AVTransport-1/service.xml /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-AVTransport-1/control /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-AVTransport-1/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /4c494e4e-0026-0f22-7cc1-016177450171/Upnp/upnp.org-ConnectionManager-1/service.xml /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-ConnectionManager-1/control /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /4c494e4e-0026-0f22-7cc1-016177450171/Upnp/upnp.org-RenderingControl-1/service.xml /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-RenderingControl-1/control /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-RenderingControl-1/eventCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Linn Selekt:UPnP AV Linn Products Ltd Selekt DSM Edition uuid:4c494e4e-0026-0f22-7cc1-016177450171 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /4c494e4e-0026-0f22-7cc1-016177450171/Upnp/upnp.org-AVTransport-1/service.xml /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-AVTransport-1/control /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-AVTransport-1/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /4c494e4e-0026-0f22-7cc1-016177450171/Upnp/upnp.org-ConnectionManager-1/service.xml /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-ConnectionManager-1/control /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /4c494e4e-0026-0f22-7cc1-016177450171/Upnp/upnp.org-RenderingControl-1/service.xml /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-RenderingControl-1/control /4c494e4e-0026-0f22-7cc1-016177450171/upnp.org-RenderingControl-1/eventUPnP devices found : 1
Device #0: Linn Selekt:UPnP AV
Location: http://192.168.88.128:55178/4c494e4e-0026-0f22-7cc1-016177450171/Upnp/device.xml
Max. memory for audio buffers: 16384MB
Local devices found : 0
Interesting, the device is not stating the actions you can do (but it should actually). Can you post again your debug info while you paused playback?
Paused playback debuginfo below.
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
DSP NOT ACTIVE
AUTO: D:\Music
AUTO: D:\Setup
Tracks with no MBID: 383
Listening on fd7a:d1d1:7197:e84d:4f3:578d:47c8:11bf on port 51342
Font size: large
My Music
Streaming
Radios
Podcasts
Active method: UPnP
Ethernet
Currently playing to UPnP device at 24 bits 192kHz
Volume control: Yes
Raw DSD (msb)
http-get::text/xml:
tidalhifi.com:::*
qobuz.com:::*
DLNA 1.5: No
NrTracks: 1
MediaDuration: 0:05:04
CurrentURI: http://192.168.88.159:49152/audirvana/audio_f_0.wav
CurrentURIMetadata:
dc:titleNew Kid in Town (2013 Remaster)</dc:title>
dc:creatorEagles</dc:creator>
upnp:artistEagles</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/6376f8f4/d4c1/45d1/8a10/f6c23e7c7bd9/640x640.jpg</upnp:albumArtURI>
upnp:albumHotel California (40th Anniversary Expanded Edition)</upnp:album>
PlayMedium: NETWORK
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Session’ and send me the audirvana_studio.log file you can find by clicking the 'Open Log Folder’ button at [email protected]
Log file sent.
