Hi, from time to time it looks like the buffering of qobuz tracks is not continuing.
(I noticed behaviour like this was reported before, but the thread is closed)
My internet connection is Wired and certainly fast enough.
I never have this issue in Qobuz app.
R8brain is set to upsample with a power of 2 so it upsamples to 705.6 or 768 and this takes almost no processor usage (i7 processor runs at 4% when doing so)
My dac is able to reproduce 705.6k and 768k
I already noticed a small bug in the audio settings > Output Device
where the two last sample rate numbers show 768. I believe this should be 705.6 and 768.
Also 352.8 and 384 seem to be missing here.
(The debug info shows the values supplied by the Dac mfg are okay, see below)
(Not sure if this is causing it).
I remember Qobuz app had this issue too about 2 years ago, but after an update it suddenly was gone. Don’t know what they did to solve it? Can it be that they test the speed of a stream, and when too slow they simply abort and retry (to hope for a faster stream to start?)
Here is my debug info:
Audirvana Studio 2.2.3 (20203)
Windows 11 (22621) with 16GB physical RAM
Connected account of : Wim Hulpia
Effects plugins NOT ACTIVEUPSAMPLING:
r8brain with Power Of Two upsampling
Phase minimum phaseAUDIO VOLUME:
SW volume control: ONLIBRARY SETTINGS:
AUTO: D:\MUSIC\CD
Library database path: C:\Users\hulpi\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqliteRemote Control server:
Listening on 2a02:1811:cd18:d800:ee46:a085:396:dcf4 on port 49893ACTIVE STREAMING SERVICES
Qobuz: Connected as Qobuz Hi-Fi Sublime+=================== AUDIO DEVICE ========================
Max. memory for audio buffers: 2826MB
Local Audio Engine: WASAPI
Use max I/O buffer size: ONPreferred device:
Luidsprekers (Element Series)
Model UID:TUSBAUDIO_ENUM\VID_20B1&PID_302B&REV_0330&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f719f798-a1d2-424d-b55c-db4875736203}#{e6327cad-dcec-4949-ae8a-991e976a79d2}Currently playing in Integer Mode:
Device: 2ch 32bits Integer, 8 bytes per frame 705.6kHzActive Sample Rate: 705.6kHz
Mute during sample rate change: OFFSelected device:Luidsprekers (Element Series)
Manufacturer: Matrix Audio
Model name: Element Series
Model UID: TUSBAUDIO_ENUM\VID_20B1&PID_302B&REV_0330&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f719f798-a1d2-424d-b55c-db4875736203}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x20b1
USB Product ID: 0x302b10 available sample rates up to 768000Hz
768000Volume Control
Virtual: NoMQA capability
MQA Decoder device
DSD capability: UnhandledDevice audio channels
Channel 1 mapped to 1Audio channels in use
Simple stereo device: No1 output streams:
2 ch Integer PCM 32bit little endian 768kHzLocal devices found : 2
Device #0: Luidsprekers (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_1025125F&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ce62f267-6e72-44d1-b66a-27e155306cf3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Luidsprekers (Element Series)
Model name: Element SeriesUPnP
UPnP devices found : 1
Device #0: Denon AVR-X3500H
UID: uuid:c88c34bd-f2b2-16b6-0080-0005cdcda62e
Location: http://192.168.0.155:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon AVR-X3500HChromecast
