I have the randomly stopping tracks issue. Using Mac Mini with 4GB RAM - would an increase in memory solve this issue or am I stuck with the problem?
Hello @lerxxst,
Hello Damien, I have the same problem with Tidal hifi after the update a 3.44my Favorit Playlist is visible for about 30-45sec than disappears all, the audirvana mask is empty, whyle the musik plays from the memory, and after 1 min. or 2 i can access to my playlist e the game is repeating.
I have iliminated my PS. Bridge 1 using the USB option, but the problem is the same.
My internet gives me min. 25mb/sec by Lan and by WiFi.
I have the dube that it is a problem of Tidal server. With Qobuz hifi is everything OK.
Best regards
Werner Pabst
Have you tried to disconnect and reconnect your Tidal account?
Yes I have tryed it several times it is aktive and the lock in is automatically with every power on of my "old"Mac mini 2012.
Are there more people with the same problem.
When I use the bridge 1 PS audio with my Perfekt Wave DAC mk2 it is the same problem. The bridge plays only one title but it is another problem. In usb plays continuous if there is a reconnection at the right time to my acount otherwise the player pause and continue after the reconnection to the Tidal acount.
macOS 10.13.6 with 4096MB RAM
Registered to Paul H Marsh
Replay Gain: by album
SW volume control: ON
AUTO: /Volumes/Tunes/
Library database path: /Users/roonserver/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: NDX Model UID:Naim Audio Ltd. NDX UID:uuid:5F9EC1B3-ED59-79BB-4530-0011F6A899B0
UPnP device at http://192.168.1.102:8080/description.xml
ID 0x0 NDX Manufacturer:Naim Audio Ltd.
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/wav:*
http-get::audio/x-mpegurl:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/x-mpegurl:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: NOT_IMPLEMENTED
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 NDX Naim Audio Ltd. http://www.naimaudio.com Naim NDX network audio player NDX 20-015-0011 https://www.naimaudio.com/product/ndx 0011F6A899B0 uuid:5F9EC1B3-ED59-79BB-4530-0011F6A899B0 123810928305556upc urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt http://192.168.1.102:80/index.asp urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6A899B0UPnP devices found : 1
Device #0: ID 0x0 NDX UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A899B0 Location: http://192.168.1.102:8080/description.xml
Max. memory for audio buffers: 3072MB
Device #0: ID 0x35 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x27 Splashtop Remote Sound Manufacturer: Splashtop Inc. Model UID: com_splashtop_driver_RemoteSound:SplashtopRemoteSoundDevice UID: SplashtopRemoteSoundEngine:0
Can you reduce the maximum amount of RAM used by Audirvana to 2000MB? Are you also using the latest version of the firmware of your Naim?
I’ve tried lots of different settings for max memory without success - currently at 2005 & it still happens. Firmware is up to date
Reduce it further. If you have another computer with more RAM you can test it there. At least this will confirm if it is RAM related issues.
I’ve already tried using lower amounts with no success. The only other computers I have are PCs & I’ve already tried using them & Audrivana doesn’t work on Windows at all for me.
If more memory is required I will install it in the Mac Mini - but I’m not doing that “just to try it”. I’d prefer to know up front if this is the issue rather than go round & round in circles attempting to fix something that won’t work anyway - like I did when I installed on Windows!
Does the issue you have appears with Hi-Res tracks or also with 16/44 tracks?
Hello Damien, it happens with all kind of file, only if I choose mp3 or the Playlist is always visible and does not disappear.
In lossless e master the Playlist and the online contact with Tidal is regularly interrupt and I can’t choose another title, and normally audirvana close with error.
I’m desperate because of these issues.
The sound of audirvana is so amazing but I have to restart the software in 80 % if I want to select another title. If I don’t select anything in USB function the Playlist play continues without issues but I don’t want to use my high end hifi for background Musik I want to select titles and switching forward and backwards but it is impossible.
Process: Audirvana [329]
Path: /Applications/Audirvana.app/Contents/MacOS/Audirvana
Identifier: com.audirvana.Audirvana
Version: 3.5.44 (3574)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Audirvana [329]
User ID: 501
Date/Time: 2021-03-22 10:04:54.611 +0100
OS Version: Mac OS X 10.13.6 (17G14042)
Report Version: 12
Anonymous UUID: E335E6C0-C43F-0993-11BC-2DE9D0335D5A
Time Awake Since Boot: 580 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0:
__TEXT 0000000100000000-0000000100c80000 [ 12.5M] r-x/r-x SM=COW [/Applications/Audirvana.app/Contents/MacOS/Audirvana]
Application Specific Information:
Performing @selector(showDebugInfo:) from sender NSMenuItem 0x6000000a1800
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x00007fff68922232 strlen + 18
1 com.audirvana.Audirvana 0x0000000100823072 0x100000000 + 8532082
2 com.audirvana.Audirvana 0x00000001005f380d 0x100000000 + 6240269
3 com.audirvana.Audirvana 0x0000000100588a51 0x100000000 + 5802577
4 com.audirvana.Audirvana 0x00000001002ae678 0x100000000 + 2811512
5 com.apple.AppKit 0x00007fff3e5fea43 -[NSApplication(NSResponder) sendAction:to:from:] + 312
6 com.apple.AppKit 0x00007fff3e093213 -[NSMenuItem _corePerformAction] + 323
7 com.apple.AppKit 0x00007fff3e092f9b -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114
8 com.apple.AppKit 0x00007fff3e118c7a -[NSMenu performActionForItemAtIndex:] + 133
9 com.apple.AppKit 0x00007fff3e118be5 -[NSMenu _internalPerformActionForItemAtIndex:] + 94
10 com.apple.AppKit 0x00007fff3e118a15 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 106
11 com.apple.AppKit 0x00007fff3dfdf2a2 NSSLMMenuEventHandler + 882
12 com.apple.HIToolbox 0x00007fff3fb92904 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1541
13 com.apple.HIToolbox 0x00007fff3fb91c4d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374
14 com.apple.HIToolbox 0x00007fff3fba6f21 SendEventToEventTarget + 39
15 com.apple.HIToolbox 0x00007fff3fbf03f9 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411
16 com.apple.HIToolbox 0x00007fff3fc192ee SendMenuCommandWithContextAndModifiers + 49
17 com.apple.HIToolbox 0x00007fff3fc192aa SendMenuItemSelectedEvent + 188
18 com.apple.HIToolbox 0x00007fff3fc19184 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
19 com.apple.HIToolbox 0x00007fff3fc19b26 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 559
20 com.apple.HIToolbox 0x00007fff3fc19866 _HandleMenuSelection2 + 472
21 com.apple.AppKit 0x00007fff3dfd0acf _NSHandleCarbonMenuEvent + 244
22 com.apple.AppKit 0x00007fff3e22adde _DPSEventHandledByCarbon + 54
23 com.apple.AppKit 0x00007fff3e5fc5e2 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 914
24 com.apple.AppKit 0x00007fff3e0485dc -[NSApplication _shouldTerminate] + 1367
25 com.apple.AppKit 0x00007fff3e047ad2 -[NSApplication terminate:] + 818
26 com.apple.AppKit 0x00007fff3e5fea43 -[NSApplication(NSResponder) sendAction:to:from:] + 312
27 com.apple.AppKit 0x00007fff3e093213 -[NSMenuItem _corePerformAction] + 323
28 com.apple.AppKit 0x00007fff3e092f9b -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114
29 com.apple.AppKit 0x00007fff3e118c7a -[NSMenu performActionForItemAtIndex:] + 133
30 com.apple.AppKit 0x00007fff3e118be5 -[NSMenu _internalPerformActionForItemAtIndex:] + 94
31 com.apple.AppKit 0x00007fff3e118a15 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 106
32 com.apple.AppKit 0x00007fff3dfdf2a2 NSSLMMenuEventHandler + 882
33 com.apple.HIToolbox 0x00007fff3fb92904 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1541
34 com.apple.HIToolbox 0x00007fff3fb91c4d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374
35 com.apple.HIToolbox 0x00007fff3fba6f21 SendEventToEventTarget + 39
36 com.apple.HIToolbox 0x00007fff3fbf03f9 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411
37 com.apple.HIToolbox 0x00007fff3fc192ee SendMenuCommandWithContextAndModifiers + 49
38 com.apple.HIToolbox 0x00007fff3fc192aa SendMenuItemSelectedEvent + 188
39 com.apple.HIToolbox 0x00007fff3fc19184 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
40 com.apple.HIToolbox 0x00007fff3fc19b26 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 559
41 com.apple.HIToolbox 0x00007fff3fc19866 _HandleMenuSelection2 + 472
42 com.apple.AppKit 0x00007fff3dfd0acf _NSHandleCarbonMenuEvent + 244
43 com.apple.AppKit 0x00007fff3e22adde _DPSEventHandledByCarbon + 54
44 com.apple.AppKit 0x00007fff3e5fc5e2 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 914
45 com.apple.AppKit 0x00007fff3de5b84d -[NSApplication run] + 764
46 com.apple.AppKit 0x00007fff3de2aa3a NSApplicationMain + 804
47 libdyld.dylib 0x00007fff688d2015 start + 1
Thread 1:: Dispatch queue: com.apple.root.default-qos
0 libsystem_kernel.dylib 0x00007fff68a22a16 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff68beb589 _pthread_cond_wait + 732
2 libc++.1.dylib 0x00007fff66826cb0 std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 18
3 com.audirvana.Audirvana 0x00000001001e3d6b 0x100000000 + 1981803
4 com.audirvana.Audirvana 0x000000010014b488 0x100000000 + 1356936
5 com.audirvana.Audirvana 0x00000001001e3c5e 0x100000000 + 1981534
6 libdispatch.dylib 0x00007fff68898db8 _dispatch_client_callout + 8
7 libdispatch.dylib 0x00007fff688a5cc5 _dispatch_queue_override_invoke + 880
8 libdispatch.dylib 0x00007fff6889a9a9 _dispatch_root_queue_drain + 515
9 libdispatch.dylib 0x00007fff6889a755 _dispatch_worker_thread3 + 101
10 libsystem_pthread.dylib 0x00007fff68bea169 _pthread_wqthread + 1387
11 libsystem_pthread.dylib 0x00007fff68be9be9 start_wqthread + 13
Thread 2:
3 com.audirvana.Audirvana 0x000000010086b74b 0x100000000 + 8828747
4 libsystem_pthread.dylib 0x00007fff68bea661 _pthread_body + 340
5 libsystem_pthread.dylib 0x00007fff68bea50d _pthread_start + 377
6 libsystem_pthread.dylib 0x00007fff68be9bf9 thread_start + 13
Thread 3:
2 com.audirvana.Audirvana 0x00000001000e2010 0x100000000 + 925712
3 com.audirvana.Audirvana 0x00000001000e1d13 0x100000000 + 924947
Thread 4:
0 libsystem_kernel.dylib 0x00007fff68a22cf2 __select + 10
1 com.audirvana.Audirvana 0x00000001000e7dc3 0x100000000 + 949699
2 com.audirvana.Audirvana 0x00000001000e1d13 0x100000000 + 924947
3 libsystem_pthread.dylib 0x00007fff68bea661 _pthread_body + 340
4 libsystem_pthread.dylib 0x00007fff68bea50d _pthread_start + 377
5 libsystem_pthread.dylib 0x00007fff68be9bf9 thread_start + 13
Thread 5:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff68a191fa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff68a18714 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff408dadc5 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff408da117 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff408d9787 CFRunLoopRunSpecific + 487
5 com.apple.AppKit 0x00007fff3dfa3fc4 _NSEventThread + 184
6 libsystem_pthread.dylib 0x00007fff68bea661 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff68bea50d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff68be9bf9 thread_start + 13
Thread 6:: com.apple.CFSocket.private
1 com.apple.CoreFoundation 0x00007fff409148ab __CFSocketManager + 635
2 libsystem_pthread.dylib 0x00007fff68bea661 _pthread_body + 340
3 libsystem_pthread.dylib 0x00007fff68bea50d _pthread_start + 377
4 libsystem_pthread.dylib 0x00007fff68be9bf9 thread_start + 13
Thread 7:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff3fa19158 -[__CoreSchedulingSetRunnable runForever] + 722
6 com.apple.Foundation 0x00007fff42a039d8 NSThread__start + 1197
7 libsystem_pthread.dylib 0x00007fff68bea661 _pthread_body + 340
8 libsystem_pthread.dylib 0x00007fff68bea50d _pthread_start + 377
9 libsystem_pthread.dylib 0x00007fff68be9bf9 thread_start + 13
Thread 8:
3 com.apple.JavaScriptCore 0x00007fff445878a6 void std::__1::condition_variable_any::wait<std::__1::unique_lockbmalloc::Mutex >(std::__1::unique_lockbmalloc::Mutex&) + 86
4 com.apple.JavaScriptCore 0x00007fff4458755b bmalloc::Scavenger::threadRunLoop() + 251
5 com.apple.JavaScriptCore 0x00007fff44587359 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9
6 com.apple.JavaScriptCore 0x00007fff44587698 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_deletestd::__1::__thread_struct >, void ()(bmalloc::Scavenger), bmalloc::Scavenger*> >(void*) + 40
Thread 9:
2 com.audirvana.Audirvana 0x00000001000e1c1a 0x100000000 + 924698
Thread 10:
Thread 11:
Thread 12:
Thread 13:: Dispatch queue: com.apple.root.default-qos
3 com.audirvana.Audirvana 0x00000001008be6db 0x100000000 + 9168603
5 com.audirvana.Audirvana 0x00000001008bdece 0x100000000 + 9166542
Thread 14:: Dispatch queue: com.apple.root.default-qos
Thread 15:: Dispatch queue: com.apple.root.default-qos
Thread 16:: Dispatch queue: com.apple.root.default-qos
Thread 17:
0 libsystem_kernel.dylib 0x00007fff68a2328a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff68bea009 _pthread_wqthread + 1035
2 libsystem_pthread.dylib 0x00007fff68be9be9 start_wqthread + 13
Thread 18:
Thread 19:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000100b3f00e rbp: 0x00007ffeefbfd760 rsp: 0x00007ffeefbfd760
r8: 0x000000000000002a r9: 0x0000000000000020 r10: 0x0000000010121191 r11: 0x00000000010688e8
r12: 0x0000000101288d70 r13: 0x00007ffeefbfd921 r14: 0x00007ffeefbfd7b8 r15: 0x00007ffeefbfd7b8
rip: 0x00007fff68922232 rfl: 0x0000000000010246 cr2: 0x0000000000000000
Logical CPU: 1
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x100000000 - 0x100c7ff67 +com.audirvana.Audirvana (3.5.44 - 3574) /Applications/Audirvana.app/Contents/MacOS/Audirvana
0x100d98000 - 0x100dd7fff com.apple.iTunesLibrary (12.8.2 - 12.8.2) <68DDB4B8-4064-3B32-8B26-641C6B2A4931> /Library/Frameworks/iTunesLibrary.framework/iTunesLibrary
0x100dff000 - 0x100e12fff +libdsd2pcm.dylib (0) /Applications/Audirvana.app/Contents/Frameworks/libdsd2pcm.dylib
0x100e7b000 - 0x100ea3ff7 +com.izotope.izresampler (1) <51297039-58D3-34DC-829E-68CF8B8DE299> /Applications/Audirvana.app/Contents/Frameworks/iZotope_Resampler.framework/Versions/A/iZotope_Resampler
0x100eac000 - 0x100f2ffff +liblibsox.dylib (0) <15CA7DD4-E297-388B-9D9E-C36DFD84D135> /Applications/Audirvana.app/Contents/Frameworks/liblibsox.dylib
0x100f50000 - 0x100f87fcb +libwavpack.dylib (0) <6258FE33-5A02-33F0-8565-D2DE6D387347> /Applications/Audirvana.app/Contents/Frameworks/libwavpack.dylib
0x100f98000 - 0x100febff7 +org.sparkle-project.Sparkle (1.24.0 a-67-g0e162c98 - 1.24.0) <1AAA2191-6EA6-35D4-BA37-24C404CE4C29> /Applications/Audirvana.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x1053bc000 - 0x1053c0ffb com.apple.audio.AppleHDAHALPlugIn (281.52 - 281.52) <88340250-72ED-375D-8DC7-3341A6B8928A> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x10661f000 - 0x106669adf dyld (551.5) /usr/lib/dyld
0x10d921000 - 0x10dc0dfff com.apple.driver.AppleIntelHD3000GraphicsGLDriver (10.4.14 - 10.0.4) /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver
0x1140cf000 - 0x114277ff7 com.apple.audio.units.Components (1.14 - 1.14) <85C6E01E-2BF4-331D-ACA5-F528B6258318> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x7fff38b75000 - 0x7fff38ec3ff7 com.apple.RawCamera.bundle (8.05.0 - 1017.4.1) <937CBA8D-60C8-3739-8DFF-1C737D6339EF> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff3c797000 - 0x7fff3c977ff3 com.apple.avfoundation (2.0 - 1536.36) /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff3c978000 - 0x7fff3ca31fff com.apple.audio.AVFAudio (1.0 - ???) <716306C4-A0EA-3D81-8F33-943153538C47> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff3cb37000 - 0x7fff3cb37fff com.apple.Accelerate (1.11 - Accelerate 1.11) <2EF00EFE-06E8-3082-85C3-2988B422A19D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff3cb38000 - 0x7fff3cb4fff7 libCGInterfaces.dylib (417.2) <82F29CAE-C0AC-3E29-8312-09E6FED7E067> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff3cb50000 - 0x7fff3d29effb com.apple.vImage (8.1 - ???) <56C275C1-459F-37CD-BF29-2E6D81C29E53> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff3d29f000 - 0x7fff3d43fff3 libBLAS.dylib (1211.50.2) <93259222-2D94-333D-A1EB-09C6FC4A64B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff3d440000 - 0x7fff3d47afef libBNNS.dylib (38.1) <0AAE0109-71D5-3B26-8401-3E62DDF97624> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff3d47b000 - 0x7fff3d854ff7 libLAPACK.dylib (1211.50.2) <70781D0B-AEAD-33EB-9900-10DC30F37D61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff3d855000 - 0x7fff3d86bff7 libLinearAlgebra.dylib (1211.50.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff3d86c000 - 0x7fff3d871ff3 libQuadrature.dylib (3) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff3d872000 - 0x7fff3d8f2fff libSparse.dylib (79.50.2) <0DC25CDD-F8C1-3D6E-B472-8B060708424F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff3d8f3000 - 0x7fff3d905ff7 libSparseBLAS.dylib (1211.50.2) <994A7D7E-FA3B-3943-A59C-8150B9AF86BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff3d906000 - 0x7fff3da79fe7 libvDSP.dylib (622.50.5) <4BF310F4-31A3-3DA5-80E4-7F8014AD380B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff3da7a000 - 0x7fff3db30fef libvMisc.dylib (622.50.5) <88143A88-4FDE-35A1-85FE-54FF0C2A9E43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff3db31000 - 0x7fff3db31fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <880DEF40-389A-3F56-ACA1-B62A5BC57E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff3de25000 - 0x7fff3ec83fff com.apple.AppKit (6.9 - 1561.61.100) <4E6EA3FA-8C2C-3B21-BFF9-6F8C458B7BE1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff3ecd5000 - 0x7fff3ecd5fff com.apple.ApplicationServices (48 - 50) <2B5B76E7-0AB2-31F9-BE58-B963BF1EC2E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff3ecd6000 - 0x7fff3ed3cfff com.apple.ApplicationServices.ATS (377 - 445.5) <60176327-F757-308E-B61A-D43394E87CC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff3edd5000 - 0x7fff3eef7ff7 libFontParser.dylib (222.1.9) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff3eef8000 - 0x7fff3ef43ff7 libFontRegistry.dylib (221.6) <30C6D1DE-C0E3-3447-A0EF-829443D95F0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff3efe8000 - 0x7fff3f01bff7 libTrueTypeScaler.dylib (222.1.9) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff3f085000 - 0x7fff3f089ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <04764FB2-22D8-36F0-9647-2D21562E28D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff3f129000 - 0x7fff3f17bffb com.apple.HIServices (1.22 - 625) <3C059A55-1409-373E-BF0B-C3299AFABDCF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff3f17c000 - 0x7fff3f18afff com.apple.LangAnalysis (1.7.0 - 1.7.0) <8BB267F4-D5AA-3D35-8269-1A3CEA054ACD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff3f18b000 - 0x7fff3f1d7fff com.apple.print.framework.PrintCore (13.4 - 503.2) <2EA98448-9D6A-3912-9933-F7703CB01B6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff3f1d8000 - 0x7fff3f212fff com.apple.QD (3.12 - 404.2) <525E9518-DFF3-3D8D-BD48-E0D63EEDBD16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff3f213000 - 0x7fff3f21ffff com.apple.speech.synthesis.framework (7.8.1 - 7.8.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff3f220000 - 0x7fff3f4aeff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff3f4b0000 - 0x7fff3f4b0fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <294802B9-E24D-34EB-973F-6D2B8E2E86CB> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff3f4b1000 - 0x7fff3f5f1ff3 com.apple.AudioVideoBridging (683.1 - 683.1) <4D8B8E76-C173-3522-968F-33B2AB56E2A8> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x7fff3f7d3000 - 0x7fff3fb70fff com.apple.CFNetwork (902.6 - 902.6) <46168F79-CCFA-349A-8508-B8CBCE27D440> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff3fb85000 - 0x7fff3fb85fff com.apple.Carbon (158 - 158) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3fb86000 - 0x7fff3fb89ffb com.apple.CommonPanels (1.2.6 - 98) <075486A5-8E39-3F72-BED7-752517379C55> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3fb8a000 - 0x7fff3fe8ffff com.apple.HIToolbox (2.1.1 - 911.10) <8D2EBE85-9AF0-38BC-ACD3-1ED978643907> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3fe90000 - 0x7fff3fe93ffb com.apple.help (1.3.8 - 66) <7F210C1C-D7D3-3C97-A2E4-D3CC35F91807> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff3fe94000 - 0x7fff3fe99fff com.apple.ImageCapture (9.0 - 9.0) <3993E094-AB86-3B22-BC18-4550F23854FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff3fe9a000 - 0x7fff3ff2fffb com.apple.ink.framework (10.9 - 221) <83976BB8-A423-3AA5-8221-6EB04B3DEF0A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff3ff30000 - 0x7fff3ff4aff7 com.apple.openscripting (1.7 - 174) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff3ff6b000 - 0x7fff3ff6cfff com.apple.print.framework.Print (12 - 267) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3ff6d000 - 0x7fff3ff6fff7 com.apple.securityhi (9.0 - 55006) <1AB48F32-D1CB-3657-A30C-40A7E718A71D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff3ff70000 - 0x7fff3ff76fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2A07BB54-438B-34C9-8061-45403E197ACA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff40097000 - 0x7fff40097fff com.apple.Cocoa (6.11 - 22) <3269BC26-0217-39FE-A600-D702656D838B> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff400a5000 - 0x7fff4015efff com.apple.ColorSync (4.13.0 - 3325) /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff402eb000 - 0x7fff4037eff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff40380000 - 0x7fff403e4ff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <676725EA-AF58-3ED7-A163-B58B2AA5011D> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x7fff403e5000 - 0x7fff4040effb com.apple.CoreBluetooth (1.0 - 1) /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff4040f000 - 0x7fff40773ff3 com.apple.CoreData (120 - 851) <283AF401-07BC-3D50-9B8C-7990E64F66BA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff40774000 - 0x7fff40857fff com.apple.CoreDisplay (99.14 - 99.14) <9B2B211D-EC0A-3569-BB37-887768CD6105> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff40858000 - 0x7fff40cf4fff com.apple.CoreFoundation (6.9 - 1455.300) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff40cf6000 - 0x7fff41325ff7 com.apple.CoreGraphics (2.0 - 1161.21.5) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff41327000 - 0x7fff41616fff com.apple.CoreImage (13.0.0 - 579.5) /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff41683000 - 0x7fff416c8fff com.apple.audio.midi.CoreMIDI (1.10 - 88) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff418a5000 - 0x7fff4199bffb com.apple.CoreMedia (1.0 - 2276.80.4) <67942D16-3658-37FC-B61C-8ED3D4BFBFB9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff4199c000 - 0x7fff419eafff com.apple.CoreMediaIO (814.0 - 4995) <2A174DD1-431A-3313-9837-04C7E1B284B6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff419eb000 - 0x7fff419ebfff com.apple.CoreServices (822.37 - 822.37) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff419ec000 - 0x7fff41a60ffb com.apple.AE (735.2 - 735.2) <0938A72B-6A4A-36F1-95B3-5EF6B915CEEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff41a61000 - 0x7fff41d38fff com.apple.CoreServices.CarbonCore (1178.4.2 - 1178.4.2) <4692EE3A-11FE-31FD-AF5B-30F892E87A05> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff41d39000 - 0x7fff41d6dfff com.apple.DictionaryServices (1.2 - 284.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff41d6e000 - 0x7fff41d76ffb com.apple.CoreServices.FSEvents (1239.50.2 - 1239.50.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff41d77000 - 0x7fff41f35ff7 com.apple.LaunchServices (822.37 - 822.37) <0DB4679F-AE39-3BF3-B39B-549322E355AF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff41f36000 - 0x7fff41fe6fff com.apple.Metadata (10.7.0 - 1191.8) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff41fe7000 - 0x7fff42047fff com.apple.CoreServices.OSServices (822.37 - 822.37) <564DDE70-0250-346B-B5CC-4AFAC11A7373> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff42048000 - 0x7fff420b6fff com.apple.SearchKit (1.4.0 - 1.4.0) <97DD9E7D-3567-382B-ACF7-CE0E4FE78D36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff420b7000 - 0x7fff420dbffb com.apple.coreservices.SharedFileList (71.21 - 71.21) <88991F51-0A75-34FF-8C91-ED0F3C270B7B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff4237c000 - 0x7fff424ccfff com.apple.CoreText (352.0 - 578.23) <10DAF601-85A8-3F9C-8B0B-69DC16B95E47> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff424cd000 - 0x7fff42507fff com.apple.CoreVideo (1.8 - 0.0) <0DD4FFDF-E1F1-39D1-8246-5D0D9869F1EA> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff42508000 - 0x7fff42593ff3 com.apple.framework.CoreWLAN (13.0 - 1350.2) /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff4272d000 - 0x7fff427e7fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <65019C7F-81C7-37DC-9B27-7EE140C8FD7C> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff4280e000 - 0x7fff42813fff com.apple.DiskArbitration (2.7 - 2.7) <51DC4AED-6F0C-321F-93E3-20EA4341B768> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff429d4000 - 0x7fff42d9bffb com.apple.Foundation (6.9 - 1455.300) <0479E072-1DD0-3881-A9A2-EDAD3EE58C23> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff42e0c000 - 0x7fff42e3cff3 com.apple.GSS (4.0 - 2.0) <7E83A21E-4F90-38F3-9FD3-FAC0E0143243> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff42f4e000 - 0x7fff43052ffb com.apple.Bluetooth (6.0.7 - 6.0.7f22) <08E33A6B-16A7-3E4E-82C9-E1E5A84300D0> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff430b2000 - 0x7fff4314dfff com.apple.framework.IOKit (2.0.2 - 1445.71.6) <4B5C715C-6A49-366B-9080-ABADE6A3B3BD> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff4314f000 - 0x7fff43156fff com.apple.IOSurface (211.15 - 211.15) <08DA3232-805F-304B-80DD-C86B49CC4AAD> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff43157000 - 0x7fff431acff3 com.apple.ImageCaptureCore (7.0 - 7.0) <5B5C36EE-69EE-39E8-8B5B-360EF3F4AC3A> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff431ad000 - 0x7fff4332bfff com.apple.ImageIO.framework (3.3.0 - 1739.3.8) /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff4332c000 - 0x7fff43330ffb libGIF.dylib (1739.3.8) <003D0895-622E-3312-9DB3-F7B7BFD33AEE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff43331000 - 0x7fff43418ff7 libJP2.dylib (1739.3.8) <9CD47B18-AAD7-379F-B04F-606B97CC62EA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff43419000 - 0x7fff4343cfff libJPEG.dylib (1739.3.8) <67715B7F-83C3-3A0E-9F1C-8B69041E1E3E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff4372d000 - 0x7fff43753ff3 libPng.dylib (1739.3.8) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff43754000 - 0x7fff43756ff3 libRadiance.dylib (1739.3.8) <7F224790-D5FF-3671-BDF0-22D676E6EE6A>
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff43757000 - 0x7fff437a4ffb libTIFF.dylib (1739.3.8) <1D450863-14A2-3268-B848-037D7ABAB4B0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff43960000 - 0x7fff44646fff com.apple.JavaScriptCore (13605 - 13605.3.8) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff4465e000 - 0x7fff44677ff7 com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff44678000 - 0x7fff446adfff com.apple.LDAPFramework (2.4.28 - 194.5) <7D48401E-2038-3F2C-89F8-77472F01DC93> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff44936000 - 0x7fff4493dfff com.apple.MediaAccessibility (1.0 - 114) <00F21329-1163-3283-A882-A5DD7A12D353> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff449ed000 - 0x7fff45057ff7 com.apple.MediaToolbox (1.0 - 2276.80.4) /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff45059000 - 0x7fff450dafff com.apple.Metal (125.30 - 125.30) <67EDA241-80B1-3C67-BB2B-FF83E49FEF8D> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff450f7000 - 0x7fff45112fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <8DED0F0C-4A10-36A3-A3E2-7D3CF429ACE1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff45113000 - 0x7fff45182fef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <48F4A97F-143A-3918-AB92-6733E258E25A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff45183000 - 0x7fff451a7fff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff451a8000 - 0x7fff4528fff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <40EB0BAE-6DDE-3334-A28C-529AE4C6716A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff45290000 - 0x7fff45290ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff4628f000 - 0x7fff4629bffb com.apple.NetFS (6.0 - 4.0) <02E09301-324F-3542-875D-B87B144635C8> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff49084000 - 0x7fff4908cfef libcldcpuengine.dylib (2.8.7) <78747075-B07A-39B3-A065-013FB54332F6> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff4908d000 - 0x7fff490e7ff7 com.apple.opencl (2.8.24 - 2.8.24) <429B5283-276D-372D-BB0E-EEBE1408C393> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff490e8000 - 0x7fff49104ffb com.apple.CFOpenDirectory (10.13 - 207.50.1) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff49105000 - 0x7fff49110fff com.apple.OpenDirectory (10.13 - 207.50.1) <8B54C486-14C9-3FEF-97B8-F4D6F59F75CF> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff4a28f000 - 0x7fff4a291fff libCVMSPluginSupport.dylib (16.7.4) <3E26CF2B-5074-3321-AD9E-6A667D61AA35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff4a292000 - 0x7fff4a297ffb libCoreFSCache.dylib (162.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff4a298000 - 0x7fff4a29cfff libCoreVMClient.dylib (162.12) <39951906-8566-3F9D-9EA8-EBD6084DCF73> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff4a29d000 - 0x7fff4a2a6ff3 libGFXShared.dylib (16.7.4) <81A7875B-103D-3C82-B25C-DE24E57E5C8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff4a2a7000 - 0x7fff4a2b2fff libGL.dylib (16.7.4) <2BB333D3-5C61-33DF-8545-06DF2D08B83D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff4a2b3000 - 0x7fff4a2eefe7 libGLImage.dylib (16.7.4) <4DA003CE-0B74-3FE4-808C-B2FBCE517EB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff4a2ef000 - 0x7fff4a45cff3 libGLProgrammability.dylib (16.7.4) <1F7FE846-FDAF-3B3E-85AE-2FD0D0C46803> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff4a45d000 - 0x7fff4a49bffb libGLU.dylib (16.7.4) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff4ae13000 - 0x7fff4ae22ff3 com.apple.opengl (16.7.4 - 16.7.4) <77A788F3-8F0C-305C-AEB9-FF258676C599> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff4ae23000 - 0x7fff4afbaff3 GLEngine (16.7.4) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff4afbb000 - 0x7fff4afe3ffb GLRendererFloat (16.7.4) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff4b1a1000 - 0x7fff4b2edff7 com.apple.QTKit (7.7.3 - 3014.8) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff4b2ee000 - 0x7fff4b553ff7 com.apple.imageKit (3.0 - 1043) <1E72C513-391D-37CE-96D1-D2B59E2F23CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff4b554000 - 0x7fff4b643ff3 com.apple.PDFKit (1.0 - 677.68) <07888D80-F4FD-38AD-8F21-48F59E486886> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff4b644000 - 0x7fff4bb56ff7 com.apple.QuartzComposer (5.1 - 364) <0C9739CE-DCEA-3732-B3F4-EFB74464C9BC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff4bb57000 - 0x7fff4bb7afff com.apple.quartzfilters (1.10.0 - 1.10.0) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff4bb7b000 - 0x7fff4bc74ff7 com.apple.QuickLookUIFramework (5.0 - 743.13) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff4bc75000 - 0x7fff4bc75fff com.apple.quartzframework (1.5 - 21) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff4bc76000 - 0x7fff4bec2ff7 com.apple.QuartzCore (1.11 - 584.64.2) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff4bec3000 - 0x7fff4bf1aff7 com.apple.QuickLookFramework (5.0 - 743.13) <4EA17C20-5BD9-335F-8EE1-D4AE16BE6A15> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff4c0e0000 - 0x7fff4c0faffb com.apple.SafariServices.framework (13609 - 13609.3.5.1.5) <8102DF3E-2C36-3B47-B10E-B990DABCF95D> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff4c6e2000 - 0x7fff4c6f9fff com.apple.ScriptingBridge (1.3.3 - 70) /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff4c6fa000 - 0x7fff4ca25fff com.apple.security (7.0 - 58286.70.19) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff4ca26000 - 0x7fff4cab2ff7 com.apple.securityfoundation (6.0 - 55185.50.5) <3D9AD4EF-439C-3AE1-9332-AD291CF96C64> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff4cae4000 - 0x7fff4cae8ffb com.apple.xpc.ServiceManagement (1.0 - 1) <3FCAF325-40C8-3148-9E49-E555F95B2946> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff4ce8d000 - 0x7fff4cefdff3 com.apple.SystemConfiguration (1.17 - 1.17) <41D509AB-AED3-30FF-BB00-615BB5A8AC00> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff4d0b2000 - 0x7fff4d42dfff com.apple.VideoToolbox (1.0 - 2276.80.4) <1C94A509-0372-3B58-94BC-4488C042BD79> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff4d6d5000 - 0x7fff4dc34feb libwebrtc.dylib (7605.3.8) <72740A61-2531-3D72-ACF4-4B85B96D8C2A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff4dc35000 - 0x7fff4f308ff7 com.apple.WebCore (13605 - 13605.3.8) <72D9EE25-F9A2-3D9E-AF94-3AC54CFBE4FE> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff4f309000 - 0x7fff4f4f0ff7 com.apple.WebKitLegacy (13605 - 13605.3.8) <52D6E336-949A-30B6-B0A3-CCE25672C050> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff4f4f1000 - 0x7fff4f98afff com.apple.WebKit (13605 - 13605.3.8) <1DDB40C0-5FB6-3495-B4CD-52D32251F88D> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff4fdfa000 - 0x7fff4fe8dff3 com.apple.APFS (1.0 - 1) <70034B32-9347-30FB-9DDE-95061F686613> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff50aba000 - 0x7fff50ae2fff com.apple.framework.Apple80211 (13.0 - 1370.4) /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff50ae4000 - 0x7fff50af3fef com.apple.AppleFSCompression (96.60.1 - 1.0) /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff50bf2000 - 0x7fff50bfdff7 com.apple.AppleIDAuthSupport (1.0 - 1) <924EA55F-1C87-347F-9212-F79EA2B2C84C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff50c37000 - 0x7fff50c7fff3 com.apple.AppleJPEG (1.0 - 1) <15558577-08E3-3087-86A9-8B6247978BCE> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff50cb1000 - 0x7fff50cb9ff3 com.apple.AppleSRP (5.0 - 1) <825BC81F-2A23-3DD6-ADCA-BF685CA3CEFC> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff50cba000 - 0x7fff50ce2fff com.apple.applesauce (1.0 - ???) <9CE4CAE2-30B9-3DF6-9BC0-33D532D7B937> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff50dab000 - 0x7fff50daefff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <62DC46E4-5D00-3EAF-94C8-0F45592F90D6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff50daf000 - 0x7fff50dffff7 com.apple.AppleVAFramework (5.0.41 - 5.0.41) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff51010000 - 0x7fff51028fff com.apple.AudioServerApplication (1.0 - 400.1.1) <5FE62AE8-0BF9-3BB4-A093-63A7983DFB2E> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
0x7fff51135000 - 0x7fff513ceffb com.apple.AuthKit (1.0 - 1) /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff51505000 - 0x7fff5150cff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff5150d000 - 0x7fff51594ff7 com.apple.backup.framework (1.9.6 - 1.9.6) <0A54D219-E71B-3BC6-8DFC-11ED47E431BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff5159d000 - 0x7fff515a3ff7 com.apple.BezelServicesFW (305.1 - 305.1) <30FB8483-B8E4-3DA8-912F-6DF76D4CE2F6> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
0x7fff5160e000 - 0x7fff5164afff com.apple.bom (14.0 - 194.2.4) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff52378000 - 0x7fff523c7ff3 com.apple.ChunkingLibrary (189 - 189) /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff52f50000 - 0x7fff52f59ff3 com.apple.CommonAuth (4.0 - 2.0) <21AF4AC2-E650-35F9-AB33-3EBA2769FBC0> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff53295000 - 0x7fff5369dfff com.apple.CoreAUC (259.0.0 - 259.0.0) /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff5369e000 - 0x7fff536ceff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <6AC79B1F-0A12-34A4-BC0D-5A6A65ABABE0> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff536e6000 - 0x7fff53713fff com.apple.CoreAnalytics.CoreAnalytics (1.0 - 1) <90AB3AF3-2B5F-3656-A1D7-0859239C28AC> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff53765000 - 0x7fff537b7ff7 com.apple.corebrightness (1.0 - 1) <60643D9E-25C6-3A48-867E-9444B2181669> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff538f6000 - 0x7fff538ffff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <4F00CAE3-4C99-3064-AB48-4DC1CCFCDE84> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff53a6d000 - 0x7fff53a7dff7 com.apple.CoreEmoji (1.0 - 69.3) /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff53d81000 - 0x7fff53d97ff7 com.apple.CoreMediaAuthoring (2.2 - 956) /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff540c6000 - 0x7fff540cbff7 com.apple.CoreOptimization (1.0 - 1) /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff540cc000 - 0x7fff54171fff com.apple.CorePDF (4.0 - 414) <320B28D5-5115-3C4B-9AEC-6114305DFACA> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff54211000 - 0x7fff54219ff3 com.apple.CorePhoneNumbers (1.0 - 1) <3B388768-5CDB-341A-BCE2-4047EAD009EA> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff5421a000 - 0x7fff54276fff com.apple.CorePrediction (1.0 - 1) <2BD07E9C-5F35-3177-B084-D09AF42E7818> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff543a4000 - 0x7fff543d5ff3 com.apple.CoreServicesInternal (309.1 - 309.1) <9A9DE5A0-3912-3311-A351-2B7B5C35D1F0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff5474f000 - 0x7fff547e0fff com.apple.CoreSymbolication (9.3 - 64026.2) <30652FA5-C731-3A22-864D-DF6D9C77CD4C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff54863000 - 0x7fff54998fff com.apple.coreui (2.1 - 494.1) <5B4F3E9C-A4EF-3908-A035-59B8631C3685> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff54999000 - 0x7fff54acafff com.apple.CoreUtils (5.6 - 560.11) <2C5A0610-1F08-3603-8692-EE03E62EE622> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff54b1f000 - 0x7fff54b83fff com.apple.framework.CoreWiFi (13.0 - 1350.2) <500CC54F-A6CB-3D36-9BB1-C9C9F6A6E414> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff54b84000 - 0x7fff54b94ff7 com.apple.CrashReporterSupport (10.13 - 1) <1ADEC140-4838-3976-A14B-6268C5251481> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff54c13000 - 0x7fff54c22ff7 com.apple.framework.DFRFoundation (1.0 - 191.7) /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff54c25000 - 0x7fff54c29ffb com.apple.DSExternalDisplay (3.1 - 380) <13AA3B17-E649-3B7B-B09D-9AE7C4A60887> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff54cab000 - 0x7fff54d21fff com.apple.datadetectorscore (7.0 - 590.3) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff54d6f000 - 0x7fff54dafff7 com.apple.DebugSymbols (181.0 - 181.0) <702DB951-F5A6-3155-9D84-BBA9A4B4E1BD> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff54db0000 - 0x7fff54edffff com.apple.desktopservices (1.12.5 - 1.12.5) <96BB57E2-3359-3920-AA7C-BF03C2225485> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff54feb000 - 0x7fff550bdff7 com.apple.DiskImagesFramework (480.60.3 - 480.60.3) <252D5F18-01F9-353C-A09C-9C282D23E574> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff551ad000 - 0x7fff551b1ff7 com.apple.DisplayServicesFW (3.1 - 380) <921A2830-1A66-396E-A689-CD85B4B8F82C> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff5523a000 - 0x7fff5523dfff com.apple.EFILogin (2.0 - 2) <04064D1B-FF9B-33D6-AE0C-5D2CD49334DE> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff55cf4000 - 0x7fff56122fff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <06065DA3-4091-3682-A308-BF3F2E3E4AF8> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff593d2000 - 0x7fff593ddfff libGPUSupport.dylib (16.7.4) <16E276E6-27A7-36AF-A8B5-883E16B95A3A> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x7fff593ea000 - 0x7fff593effff com.apple.GPUWrangler (3.20.18 - 3.20.18) /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff597a3000 - 0x7fff597c8ff3 com.apple.GenerationalStorage (2.0 - 285.3) <0C898B63-E9A3-3D93-BB3D-CD54BFE51DED> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff5a165000 - 0x7fff5a174fff com.apple.GraphVisualizer (1.0 - 5) /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5a1f7000 - 0x7fff5a26bfff com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5a26c000 - 0x7fff5a29afff com.apple.HelpData (2.3 - 167.2) <24A1E5D9-2801-36F4-9361-692467E5B615> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff5ab7e000 - 0x7fff5ab85ff7 com.apple.IOAccelerator (378.28 - 378.28) /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5ab89000 - 0x7fff5aba0fff com.apple.IOPresentment (1.0 - 35.1) /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5af6b000 - 0x7fff5af91ffb com.apple.IconServices (97.6 - 97.6) <7913A453-8D29-31DC-ADDB-7CEC068C9B86> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5b09e000 - 0x7fff5b0a1ff3 com.apple.InternationalSupport (1.0 - 1) /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5b10f000 - 0x7fff5b11fffb com.apple.IntlPreferences (2.0 - 227.5.2) /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff5b216000 - 0x7fff5b229ff3 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5b22a000 - 0x7fff5b31fff7 com.apple.LanguageModeling (1.0 - 159.5.3) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5b320000 - 0x7fff5b362fff com.apple.Lexicon-framework (1.0 - 33.5) /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5b366000 - 0x7fff5b36dff7 com.apple.LinguisticData (1.0 - 238.3) <6F2ED02A-2120-3ABA-8EC1-314E4FFE77F3> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5bb6e000 - 0x7fff5bb71fff com.apple.Mangrove (1.0 - 1) <471F4581-5235-3381-B16B-CE92ED6CF086> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5bc8d000 - 0x7fff5bcc0ff7 com.apple.MediaKit (16 - 873) /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff5c081000 - 0x7fff5c0eaff7 com.apple.gpusw.MetalTools (1.0 - 1) /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5c0f3000 - 0x7fff5c10aff7 com.apple.MobileAssets (1.0 - 437.60.1) <94912D67-E290-3205-B919-C70C0A8D7FCF> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5c10e000 - 0x7fff5c279ff7 com.apple.mobiledevice (988.250.11.100.2 - 988.250.11.100.2) /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x7fff5c27a000 - 0x7fff5c293fff com.apple.MobileKeyBag (2.0 - 1.0) <9EA31672-3B83-3ABF-B2D5-8584E159051E> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5c31f000 - 0x7fff5c349ffb com.apple.MultitouchSupport.framework (1614.1 - 1614.1) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5c5b0000 - 0x7fff5c5bbfff com.apple.NetAuth (6.2 - 6.2) <85C5D94D-C67E-36DC-B0EA-02F53AC4FCD3> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5de57000 - 0x7fff5de67ffb com.apple.PerformanceAnalysis (1.194 - 194) /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5fbce000 - 0x7fff5fc25fff com.apple.ProtectedCloudStorage (1.0 - 1) <29C0FB61-2227-3648-AD01-502B1DDA63ED> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff5fc26000 - 0x7fff5fc44fff com.apple.ProtocolBuffer (1 - 260) <195906B1-1DB1-3AD2-B2F7-87B867C27F40> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff5fdb1000 - 0x7fff5fdc7ff7 com.apple.QuickLookThumbnailing (1.0 - 1) <043881FB-D325-3145-99B9-B9307AF99365> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff5fe0e000 - 0x7fff5fe1afff com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.70.16) /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff5fe1b000 - 0x7fff5fe3effb com.apple.RemoteViewServices (2.0 - 125) <695CBF89-C15C-3E4C-8045-B46DCA64E3FB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff5fe3f000 - 0x7fff5fe54ff3 com.apple.xpc.RemoteXPC (1.0 - 1205.70.16) /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff61764000 - 0x7fff61879ff7 com.apple.Sharing (1050.22.9 - 1050.22.9) /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff6187a000 - 0x7fff61899ff7 com.apple.shortcut (2.16 - 99) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff618a4000 - 0x7fff618a5ff7 com.apple.performance.SignpostNotification (1.2.6 - 2.6) /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff62603000 - 0x7fff628a0fff com.apple.SkyLight (1.600.0 - 312.103.12) /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff63069000 - 0x7fff63076fff com.apple.SpeechRecognitionCore (4.6.1 - 4.6.1) <90CDCEAD-5A65-3C35-9370-2B306895E97C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff63523000 - 0x7fff6354afff com.apple.StreamingZip (1.0 - 1) /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff63c1c000 - 0x7fff63ca5fc7 com.apple.Symbolication (9.3 - 64033) /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff64216000 - 0x7fff6421eff7 com.apple.TCC (1.0 - 1) <9D5466C6-A8B6-3C24-A791-6506B81D9998> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff6442b000 - 0x7fff644e8ff7 com.apple.TextureIO (3.7 - 3.7) <32C460CD-E93D-3FA5-A4AE-CA648722F5FE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff64510000 - 0x7fff6453eff7 com.apple.TimeSync (1.0 - 680.15) <05174A4C-C6E1-366D-8415-CEC62DB17E0B> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x7fff64592000 - 0x7fff64593fff com.apple.TrustEvaluationAgent (2.0 - 31) /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff64599000 - 0x7fff64749fff com.apple.UIFoundation (1.0 - 547.9) /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff6541e000 - 0x7fff654edff7 com.apple.ViewBridge (343.2 - 343.2) <0A295791-B763-3E58-A9DD-8E4F40E815C9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff658c8000 - 0x7fff65af3ffb libAWDSupportFramework.dylib (794) <65E56B9D-5B2F-3062-A9D9-0CFE5764E4AA> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff65af4000 - 0x7fff65b05ff7 libprotobuf-lite.dylib (794) <015C93F6-2ABD-368C-A1A4-0A91C07A6D9F> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff65b06000 - 0x7fff65b68fff libprotobuf.dylib (794) <90DCFF25-C3F1-31D3-B87B-ECEE7DE8A3BA> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff65b69000 - 0x7fff65bacff7 com.apple.awd (1.0 - 930) /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff65ec5000 - 0x7fff65ec7ffb com.apple.loginsupport (1.0 - 1) /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6602e000 - 0x7fff66061ff7 libclosured.dylib (551.5) <112BC241-6626-3848-8DD8-B34B5B6F7ABC> /usr/lib/closure/libclosured.dylib
0x7fff6611b000 - 0x7fff66154ff7 libCRFSuite.dylib (41) <14B00FCF-4C67-3736-95B5-76FEA6E4972C> /usr/lib/libCRFSuite.dylib
0x7fff66155000 - 0x7fff66160fff libChineseTokenizer.dylib (28) <2237A259-0E59-3DD0-BADC-281C361FAB70> /usr/lib/libChineseTokenizer.dylib
0x7fff66161000 - 0x7fff661eeff7 libCoreStorage.dylib (546.50.1) <19017524-8E8B-3A92-97F1-C7701F81C449> /usr/lib/libCoreStorage.dylib
0x7fff661f2000 - 0x7fff661f3ff3 libDiagnosticMessagesClient.dylib (104) <3F855622-352B-3EA8-B7C8-94D1DB48C080> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6622a000 - 0x7fff663f4ff3 libFosl_dynamic.dylib (17.8) <1A2A9D53-129E-3F7D-AE23-1D6E6D9EA017> /usr/lib/libFosl_dynamic.dylib
0x7fff6642c000 - 0x7fff6642cfff libOpenScriptingUtil.dylib (174) /usr/lib/libOpenScriptingUtil.dylib
0x7fff66563000 - 0x7fff66567ffb libScreenReader.dylib (562.18.5) /usr/lib/libScreenReader.dylib
0x7fff66568000 - 0x7fff66569ffb libSystem.B.dylib (1252.50.4) <5A02016C-8F9D-3F47-8C39-AD2CD4F9F11D> /usr/lib/libSystem.B.dylib
0x7fff6656a000 - 0x7fff665e7fff libTelephonyUtilDynamic.dylib (3316) <90953FEB-7E7A-371F-87AA-8BF136FD1EB9> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff665fc000 - 0x7fff665fcfff libapple_crypto.dylib (109.50.15) /usr/lib/libapple_crypto.dylib
0x7fff665fd000 - 0x7fff66613ff7 libapple_nghttp2.dylib (1.24) <24338D88-5D73-3165-9CFB-5A92734C9040> /usr/lib/libapple_nghttp2.dylib
0x7fff66614000 - 0x7fff6663eff3 libarchive.2.dylib (54) /usr/lib/libarchive.2.dylib
0x7fff6663f000 - 0x7fff66742fe7 libate.dylib (1.13.1) /usr/lib/libate.dylib
0x7fff66746000 - 0x7fff66746ff3 libauto.dylib (187) <92E693DF-D74D-39A0-99AB-8A9F6FFEBA18> /usr/lib/libauto.dylib
0x7fff66747000 - 0x7fff66800ffb libboringssl.dylib (109.50.15) /usr/lib/libboringssl.dylib
0x7fff66801000 - 0x7fff66811ff3 libbsm.0.dylib (39) <18D57879-A717-3466-9637-1704EE59A32A> /usr/lib/libbsm.0.dylib
0x7fff66812000 - 0x7fff6681fffb libbz2.1.0.dylib (38) <0B4321CD-3D6F-3095-A12E-27F66B4321AD> /usr/lib/libbz2.1.0.dylib
0x7fff66820000 - 0x7fff66876fff libc++.1.dylib (400.9) <142D6292-F30F-3949-9F37-3C97A579F540> /usr/lib/libc++.1.dylib
0x7fff66877000 - 0x7fff6689bff7 libc++abi.dylib (400.8.2) /usr/lib/libc++abi.dylib
0x7fff6689d000 - 0x7fff668adfff libcmph.dylib (6) <890DEC4C-4334-393C-8B56-7C8560BBED9D> /usr/lib/libcmph.dylib
0x7fff668ae000 - 0x7fff668c5fd3 libcompression.dylib (47.60.2) /usr/lib/libcompression.dylib
0x7fff66b70000 - 0x7fff66b88ff7 libcoretls.dylib (155.50.1) <087E9F90-21E5-376D-9956-C4E346409682> /usr/lib/libcoretls.dylib
0x7fff66b89000 - 0x7fff66b8aff3 libcoretls_cfhelpers.dylib (155.50.1) <78CCDD10-7D71-365E-A0A5-8524ED5F5BF9> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff66d23000 - 0x7fff66eb4fff libcrypto.35.dylib (22.50.3) <6E609F99-59BC-3AEA-9DB3-FD360A2C50CC> /usr/lib/libcrypto.35.dylib
0x7fff6704f000 - 0x7fff6705aff7 libcsfde.dylib (546.50.1) <5A79D6BF-EC0E-32CD-AEA4-93F164683393> /usr/lib/libcsfde.dylib
0x7fff6705b000 - 0x7fff670b0ff3 libcups.2.dylib (462.2.10) <590D6ACC-68A0-371E-8646-FC59F814534B> /usr/lib/libcups.2.dylib
0x7fff670db000 - 0x7fff6712ffff libcurl.4.dylib (105.40.2) <5F488A16-AD24-3C06-A0E5-B32D9358ED01> /usr/lib/libcurl.4.dylib
0x7fff671f0000 - 0x7fff671f0fff libenergytrace.dylib (16) <1F11D488-07C6-3D18-BEF2-0B28A992D761> /usr/lib/libenergytrace.dylib
0x7fff671f1000 - 0x7fff6720aff3 libexpat.1.dylib (16.1.1.1) /usr/lib/libexpat.1.dylib
0x7fff67218000 - 0x7fff67219fff libffi.dylib (18.1) /usr/lib/libffi.dylib
0x7fff67227000 - 0x7fff6722cff3 libheimdal-asn1.dylib (520.50.9) /usr/lib/libheimdal-asn1.dylib
0x7fff67258000 - 0x7fff67349ff7 libiconv.2.dylib (51.50.1) <7965B866-C75A-3450-9891-0500349F7090> /usr/lib/libiconv.2.dylib
0x7fff6734a000 - 0x7fff67571ffb libicucore.A.dylib (59181.0.1) <17767680-09DF-3954-AB6C-B13B41F92A2E> /usr/lib/libicucore.A.dylib
0x7fff675be000 - 0x7fff675bffff liblangid.dylib (128) /usr/lib/liblangid.dylib
0x7fff675c0000 - 0x7fff675d9ffb liblzma.5.dylib (10) <60BEAB81-CE65-3479-90CC-03325AACEC95> /usr/lib/liblzma.5.dylib
0x7fff675da000 - 0x7fff675f0ff7 libmarisa.dylib (9) <47540053-02CF-35F8-A75E-074DB3D51812> /usr/lib/libmarisa.dylib
0x7fff676a1000 - 0x7fff678c9ff7 libmecabra.dylib (779.7.6) /usr/lib/libmecabra.dylib
0x7fff67aa1000 - 0x7fff67c1cfff libnetwork.dylib (1229.70.2) <0596A03E-C984-3FE6-B88E-63D5F96EC49A> /usr/lib/libnetwork.dylib
0x7fff67ca3000 - 0x7fff680943b7 libobjc.A.dylib (723) <616AB826-9179-3924-AA61-AF760363A3F5> /usr/lib/libobjc.A.dylib
0x7fff680a7000 - 0x7fff680abfff libpam.2.dylib (22) /usr/lib/libpam.2.dylib
0x7fff680ae000 - 0x7fff680e6ff7 libpcap.A.dylib (79.20.3) <6A9D27FA-2780-3E96-8B2E-645638AC13AC> /usr/lib/libpcap.A.dylib
0x7fff68165000 - 0x7fff68181ffb libresolv.9.dylib (65.1) /usr/lib/libresolv.9.dylib
0x7fff681bd000 - 0x7fff681cffff libsasl2.2.dylib (211.0.2) /usr/lib/libsasl2.2.dylib
0x7fff681d0000 - 0x7fff681d1ff3 libspindump.dylib (252) <7BE3801C-F1F5-3F54-AB70-9842F8EF3F09> /usr/lib/libspindump.dylib
0x7fff681d2000 - 0x7fff6835fff7 libsqlite3.dylib (274.8.1) /usr/lib/libsqlite3.dylib
0x7fff683bb000 - 0x7fff6840effb libssl.35.dylib (22.50.3) <208CD5D9-F165-3DED-9DE0-BF2B349895E8> /usr/lib/libssl.35.dylib
0x7fff68461000 - 0x7fff684affff libstdc++.6.0.9.dylib (104.1) <89546A31-E404-3995-8A10-AB8CC34982AD> /usr/lib/libstdc++.6.0.9.dylib
0x7fff68533000 - 0x7fff68593ff3 libusrtcp.dylib (1229.70.2) <1E065228-D0E3-3808-9405-894056C6BEC0> /usr/lib/libusrtcp.dylib
0x7fff68594000 - 0x7fff68597ffb libutil.dylib (51.20.1) /usr/lib/libutil.dylib
0x7fff68598000 - 0x7fff685a5ff3 libxar.1.dylib (417.1) <351781D5-3CCF-320F-BB5A-4DFCC1CCD31D> /usr/lib/libxar.1.dylib
0x7fff685a9000 - 0x7fff68690ffb libxml2.2.dylib (31.20) <286F8531-7001-3989-9640-284443355433> /usr/lib/libxml2.2.dylib
0x7fff68691000 - 0x7fff686b9fff libxslt.1.dylib (15.16) <57D56366-1E7B-356C-B2B8-F4688FF666E6> /usr/lib/libxslt.1.dylib
0x7fff686ba000 - 0x7fff686ccffb libz.1.dylib (70) <47278BDC-596E-3037-B8DA-05FE9D5DBEF6> /usr/lib/libz.1.dylib
0x7fff68768000 - 0x7fff6876cff7 libcache.dylib (80) <096D3699-58D2-3D23-9512-BC88DAE7B16C> /usr/lib/system/libcache.dylib
0x7fff6876d000 - 0x7fff68777ff3 libcommonCrypto.dylib (60118.50.1) /usr/lib/system/libcommonCrypto.dylib
0x7fff68778000 - 0x7fff6877ffff libcompiler_rt.dylib (62) <4CEED002-D00B-35F8-B563-0546A5F71A43> /usr/lib/system/libcompiler_rt.dylib
0x7fff68780000 - 0x7fff68789ffb libcopyfile.dylib (146.50.5) /usr/lib/system/libcopyfile.dylib
0x7fff6878a000 - 0x7fff6880fffb libcorecrypto.dylib (562.70.3) <9C6E5CC2-272B-3740-AEDB-9EBEC98EC7F9> /usr/lib/system/libcorecrypto.dylib
0x7fff68897000 - 0x7fff688d0ff7 libdispatch.dylib (913.60.3) <285526B6-A2A6-316D-A1CC-37803B71E203> /usr/lib/system/libdispatch.dylib
0x7fff688d1000 - 0x7fff688eeff7 libdyld.dylib (551.5) <49ABA86D-DD48-3133-9B14-B9A564EEBC66> /usr/lib/system/libdyld.dylib
0x7fff688ef000 - 0x7fff688efffb libkeymgr.dylib (28) <7CC7B5E1-AB7F-3495-A26A-396461BCB66B> /usr/lib/system/libkeymgr.dylib
0x7fff688f0000 - 0x7fff688fcff3 libkxld.dylib (4570.71.82.8) <44AF05D7-6BDF-3A9B-B5CF-D16C98B6844E> /usr/lib/system/libkxld.dylib
0x7fff688fd000 - 0x7fff688fdff7 liblaunch.dylib (1205.70.16) <265EE555-E988-3EE5-A39E-028FB3A5FE11> /usr/lib/system/liblaunch.dylib
0x7fff688fe000 - 0x7fff68902ffb libmacho.dylib (906) /usr/lib/system/libmacho.dylib
0x7fff68903000 - 0x7fff68905fff libquarantine.dylib (86.70.1) <262CECFE-A493-3EC6-8608-CEA93757265E> /usr/lib/system/libquarantine.dylib
0x7fff68906000 - 0x7fff68907ff3 libremovefile.dylib (45) /usr/lib/system/libremovefile.dylib
0x7fff68908000 - 0x7fff6891ffff libsystem_asl.dylib (356.70.1) <9481D82D-CFB7-3032-A07F-88F7F59CAC2C> /usr/lib/system/libsystem_asl.dylib
0x7fff68920000 - 0x7fff68920fff libsystem_blocks.dylib (67) /usr/lib/system/libsystem_blocks.dylib
0x7fff68921000 - 0x7fff689aaff7 libsystem_c.dylib (1244.50.9) <25DD83D8-80CA-3DFF-8626-FE704911F19C> /usr/lib/system/libsystem_c.dylib
0x7fff689ab000 - 0x7fff689aeffb libsystem_configuration.dylib (963.50.9) <61B26E1D-FEFF-38C6-AE0E-A6DD90145EB2> /usr/lib/system/libsystem_configuration.dylib
0x7fff689af000 - 0x7fff689b2ffb libsystem_coreservices.dylib (51) /usr/lib/system/libsystem_coreservices.dylib
0x7fff689b3000 - 0x7fff689b4fff libsystem_darwin.dylib (1244.50.9) <6195EEA1-83A7-35F0-8147-5AB031020CD0> /usr/lib/system/libsystem_darwin.dylib
0x7fff689b5000 - 0x7fff689bbffb libsystem_dnssd.dylib (878.70.4) <0D2C9583-5D28-375B-AEB4-F66F18C78322> /usr/lib/system/libsystem_dnssd.dylib
0x7fff689bc000 - 0x7fff68a05ff7 libsystem_info.dylib (517.30.1) <9C2C96F3-638B-34E7-A2BD-24C643EAF957> /usr/lib/system/libsystem_info.dylib
0x7fff68a06000 - 0x7fff68a2cff7 libsystem_kernel.dylib (4570.71.82.8) /usr/lib/system/libsystem_kernel.dylib
0x7fff68a2d000 - 0x7fff68a78fcb libsystem_m.dylib (3147.50.1) /usr/lib/system/libsystem_m.dylib
0x7fff68a79000 - 0x7fff68a98ff7 libsystem_malloc.dylib (140.50.7) <821E16C8-7A7E-3269-9167-10F4F413BF93> /usr/lib/system/libsystem_malloc.dylib
0x7fff68a99000 - 0x7fff68bc9ff7 libsystem_network.dylib (1229.70.2) <07BFD80A-E7EB-3DEB-B765-5E1659453114> /usr/lib/system/libsystem_network.dylib
0x7fff68bca000 - 0x7fff68bd4ffb libsystem_networkextension.dylib (767.70.2) /usr/lib/system/libsystem_networkextension.dylib
0x7fff68bd5000 - 0x7fff68bdeff3 libsystem_notify.dylib (172) <738B3BB0-4F20-3446-A3B6-095D796E5903> /usr/lib/system/libsystem_notify.dylib
0x7fff68bdf000 - 0x7fff68be6ff7 libsystem_platform.dylib (161.50.1) <90A2A62F-8690-3FA7-A4D0-9085BF2FA44A> /usr/lib/system/libsystem_platform.dylib
0x7fff68be7000 - 0x7fff68bf2fff libsystem_pthread.dylib (301.50.1) <283E64A7-A2B2-3212-95BA-4D21F9AE36CF> /usr/lib/system/libsystem_pthread.dylib
0x7fff68bf3000 - 0x7fff68bf6fff libsystem_sandbox.dylib (765.70.2) /usr/lib/system/libsystem_sandbox.dylib
0x7fff68bf7000 - 0x7fff68bf8ff3 libsystem_secinit.dylib (30) <4E84DF62-57B5-36F9-819F-3C1E7FEDA856> /usr/lib/system/libsystem_secinit.dylib
0x7fff68bf9000 - 0x7fff68c00ff7 libsystem_symptoms.dylib (820.60.3) /usr/lib/system/libsystem_symptoms.dylib
0x7fff68c01000 - 0x7fff68c15ff7 libsystem_trace.dylib (829.70.2) <4C4E5351-E370-3226-9B30-61E250DE3B2E> /usr/lib/system/libsystem_trace.dylib
0x7fff68c17000 - 0x7fff68c1cff7 libunwind.dylib (35.3) /usr/lib/system/libunwind.dylib
0x7fff68c1d000 - 0x7fff68c4afff libxpc.dylib (1205.70.16) <26D99819-B813-320E-9E8F-9D57AD2DA63B> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 132
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=455.7M resident=0K(0%) swapped_out_or_unallocated=455.7M(100%)
Writable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 3
Activity Tracing 256K 2
CG backing stores 664K 4
CG image 584K 29
CoreAnimation 8328K 66
CoreGraphics 8K 2
CoreImage 16K 4
CoreUI image data 872K 11
CoreUI image file 184K 5
Foundation 4K 2
JS JIT generated code 128.0M 4
JS JIT generated code (reserved) 896.0M 2 reserved VM address space (unallocated)
Kernel Alloc Once 8K 2
MALLOC 755.6M 132
MALLOC guard page 80K 19
Memory Tag 242 12K 2
OpenGL GLSL 256K 4
SQLite page cache 64K 2
STACK GUARD 56.1M 21
Stack 17.6M 23
VM_ALLOCATE 3444K 18
WebKit Malloc 12.1M 6
__DATA 34.3M 322
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__LINKEDIT 196.4M 17
__TEXT 259.3M 322
__UNICODE 560K 2
libnetwork 5376K 21
mapped file 77.5M 26
shared memory 768K 17
TOTAL 2.4G 1063
TOTAL, minus reserved VM space 1.5G 1063
Model: Macmini5,1, BootROM 135.0.0.0.0, 2 processors, Intel Core i5, 2,3 GHz, 12 GB, SMC 1.76f0
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x0198, 0x393955353432382D3036392E4130304C4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x0198, 0x4850313644334C53314B46472F3447202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xE4), Broadcom BCM43xx 1.0 (5.106.98.102.30)
Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: INTENSO, 256,06 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: PS AudioUSB Audio 2.0
USB Device: USB Drive
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: IR Receiver
Thunderbolt Bus: Mac mini, Apple Inc., 25.1
This crash appeared when you clicked on Debug Info?
This morning it is working great, I have controlled the internet speed 37mb/sec download 12 mb/sec upload, this is more than twice the speed I have had yesterday, Sunday afternoon, it seems to be a internet speed issue, the debug info of today morning is produced during a 40 mb speed test which has caused the failed of audirvana, and this will happens all the time I am using the speetest, the Playlist disappeared the connection with tidal was lost and turned after 1 min., otherwise it was running great in both wise USB and bridgemode
I only use two sources - a Synology NAS with only flac files & Qobuz. I usually select Hi-Res if available.
It appears to affect anything I play from either source. Being random it’s difficult to recreate exactly - it can happen in nearly every track or not at all for a day.
Do we have any solutions for this issue - getting quite frustrating
