Hi guys, I’m running a trial version I just downloaded. Can’t I access files via a directory search/filename? I file my music according to: Genre>Artist/Composer>Album and this is also my preferred way to access them. I use tags for finer classification, so I can find lieder sung by a soprano for example, or list piano concertos, etc.
I’m currently using MediaMonkey; this software can access music according to many different criteria including file pathname. It also has excellent file tag editing. I’ll be sticking with it for the time being.
Thanks for the trial, I always appreciate try-before-you-buy.
Cheers
Mark
