Trouble with Origin 2.6.0
Since the update to 2.6.0 I have had the software crash. I can’t work out any reason for this???
Hi @Larkin
Do you get a report after the crash?
When you open Audirvana send a debug (Settings/My Account/Debug Info) and post those results gere for help.
Phil
Hi @Larkin ,
which OS are you using?
OS Mojave
and yes I do get a report after the crash
Debug info as…
Audirvana Origin 2.6.0 (20600)
macOS 10.14.6 x86_64 with 8GB physical RAM
Connected account of : nigel madhoo
	Per track: OFF
DSP ACTIVE in offline mode with plugins using new macOS API
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
r8brain with 2x upsampling
Bandwidth = 90.1156%
Stop band attenuation 181.211dB
Replay Gain: by album
SW volume control: ON
Sync list: 11 folders
AUTO: /Users/mad-eye/Music/FLACs/Bleep Dwnlds
AUTO: /Users/mad-eye/Music/FLACs/CHAN6642 - Handel Water Music Suites Nos_ 1-3, HWV348-350
AUTO: /Users/mad-eye/Music/FLACs/Cocteau Twins - Singles Collection Box- CD1-CD2-CD3-CD4 - Flac
AUTO: /Users/mad-eye/Music/FLACs/Eddie Henderson - Coming Through
AUTO: /Users/mad-eye/Music/FLACs/Eddie Henderson - Mahal
AUTO: /Users/mad-eye/Music/FLACs/Eddie Henderson - Sunburst
AUTO: /Users/mad-eye/Music/FLACs/Eric Gale
AUTO: /Users/mad-eye/Music/FLACs/JAZZ
AUTO: /Users/mad-eye/Music/FLACs/Sad Lovers and Giants - Epic Garden Music 1982 Midnight Music - CHIME 00.01
AUTO: /Users/mad-eye/Music/FLACs/Tom Browne - Love Approach
AUTO: /Users/mad-eye/Music/FLACs/You Are My Starship
Sync folders at startup: YES
iTunes/Music library synchronization: last synchronized on Wed Jun 11 14:59:48 2025
Sort and display order: en
Library database path: /Users/mad-eye/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on ::1 on port 49152
Font size: large
My Music
Library
Startup view: My Playlists
Use Apple Remote: no
Number of paired remotes: 1
Screen saver disabled: yes
Max. memory for audio buffers: 2042MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Topping D10
Model UID:D10:152A:8750
UID:AppleUSBAudioEngine:Topping:D10:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Hog Mode is on
Selected device:D10
Manufacturer: Topping
Model name: Topping D10
Model UID: D10:152A:8750
UID: AppleUSBAudioEngine:Topping:D10:14200000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x28
Max volume alert: Disabled
Stream ID 0x29 2 channels starting at 1
24 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
32 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Local devices found : 3
Device #0: ID 0x2d Built-in Output
Model UID: AppleHDA:108
Device #1: ID 0x34 HDMI
UID: AppleHDAEngineOutputDP:3,0,1,1:0:{9F19-2701-00000000}
Model name: Apple Inc. HDMI
Device #2: ID 0x28 D10
Ethernet
Can you please send us the latest crash report you got from Audirvāna at [email protected]?
